ocean Hull
  • SJFE
    • 4867
    I would suggest a Faigao 9XL with a minimum of 100amp ESC(a hydra 120 would be perfect) on 4s-2p lipo. They will give you about 26000 rpms unloaded or out of the water. Thats the higher end of a sport setup. As for lipo packs you can go 2 ways. You can run a set of 14.4 4s packs in parallel or a set of 7.4 2s packs in series. Series running will be a little less weight and a bit quicker. The down side is the packs are put under much more of a load and run times are reduced with lower more affordable MAHrated packs. Parallel running will give you much more run time and be easer on the packs with a little added weight. This may be better for you in ruff water. The 14.4 4s packs you will need are a bit more expensive but it avarages out. Keep in mind with longer run times your motor and esc and build heat. Even more so if you prop the boat agressively(meaning a large or high pitch prop). When shopping for lipo the (C) rating can be no less than 20 to 25 and mah should be a minimum 3300. 4000 to 6000 and above is really the way to go. Any more questions about hardware selection or radio equipment just ask :).
    • Eyekandyboats
      • 1935
      ohh, add those boats onto my list !
      man i'm going to be going overboard on boats !
      EYEKANDYGRAPHICS
      www.rclipos.com
      • SJFE
        • 4867
        You and I both Taylor. I now have no less than 7 boats 5 of witch still have to be built or setup. 2 are still in the mail & I am suposed to buy another one next week. I am well overboard.
        • frostyan
          • Dec 2007
          • 42
          SJFE I was thinking more like two-3cell lipo =22.2V . My vision peak dynamite charger can do one 3cell lipo at a time. Can that Faigao 9XL take that much V. And the hydra 120 does seem perfect I had my eye on it . Man this is going to be a sick boat.
          • SJFE
            • 4867
            That is WAY to hot of a setup. You will be turning over 40000rpm unloaded. In a word POOF. You need to run less voltage or less a motor with less turns or lower kv not to mention the HV esc. If you want a hot but relaible setup calculate rpmn unloaded to 30000. A 12XL may be the right motor IDK I have not done the math. Scoot on over to the store and X the kvm ratingsby the voltage untill you hit around 30k and there you have it.
            • frostyan
              • Dec 2007
              • 42
              my waveshark
              A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
              • Avanti
                • 1298
                the boat looks like it moves out pretty good
                btw you have a great looking pond, nice clear water
                The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                • frostyan
                  • Dec 2007
                  • 42
                  ya its a nice lake but the R/C boat club , (so i would have to get a GP to be welcome) won't let me use the lake because i have a EP boat they only use GP. last time i went my EP was faster than some of there boats and they got upset. lol so i only can go on the weekdays now. MIAMI FL beautiful water and ladys
