New idea that might be of intrest "twinline"
  • Jacked1
    • Jun 2010
    • 772
    This is an idea I have had for a reeaallyyy long time but with school have not had a chance to try it out untill now. One shaft and two motors! This will be part of the future power system for one of my boats (have not decided which one). All I did was order a 6mm shaft from mcmaster and put it through where the stock ones were. Really easy!
    I think this would be really good in monos or if someone wants to build a quad cat that looks scale that still has 2 outdrives.
    Let me know what you guys think!
    Sorry for for the spelling error in the title!
    Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
  • keithbradley
    • 3663
    I dont understand...thats one shaft going through both motors???
    If it is, I like it. I have considered teh scorpion "s" series motors that have a shaft out both ends for my road cars but the kv is always a little low in the higher watt motors. I would be very interested in something like this. I have used outrunners in the past as a direct replacement for motor/trasmission/spur gear in nitro cars. If thats not clear, I basically hook both fron tand rear driveshafts directly to the motor. No pinion, no spur. I have gotten some RWD cars to go prety fast this way, but the problem with AWD is the lack of higher kv/higher power motors with a shoft out of both ends.
    www.keithbradleyboats.com
    • Jacked1
      • Jun 2010
      • 772
      Yupp Keith that is exactly what it is! One shaft and two motors. That sound sweet with the cars! You would have that much less to break and pretty even power to the back wheels.
      It would be sweet to use 4 small outrunners and make it 4wd with the motor end being the wheel hub.
      • Diesel6401
        Memento Vivere
        • 4203
        Looks cool.
        Make sure you have the motor directions figured out before you plug them both up together. One motor going one way and the second motor going the opposite way... That could bad....
        - Diesel's Youtube
        - Diesel's Fleet
        • Jacked1
          • Jun 2010
          • 772
          Originally posted by Diesel6401 View Post
          Looks cool.
          Thanks man! I just was talking about the same thing with my dad! I ran into that problem on my twin gear drive boat.
          • Diesel6401
            Memento Vivere
            • 4203
            Yup.. I would check each motor directin seperatly then make a label or something to the esc for direction after you figure it out you. Once you get the direction right just label each esc wire a,b,c then the correct motor wire a,b,c then after you stick everything back together just match the esc/motor wires up a/a, b/b, c/c... I would also make sure when checking directions that you have each motor matched with a certain esc and not to switch them after you test. Just a suggestion of course. Good luck with your project.
            - Diesel's Youtube
            - Diesel's Fleet
            • keithbradley
              • 3663
              Im also curious about timing...it may be necessary to index these so the poles hit at the same exact time...know what I mean?
              • Jacked1
                • Jun 2010
                • 772
                Yupp! I made sure they are lined up so the tick over at the same time.
                And Deisel that is almost exactly what I did on the gear drive boat. Great minds think alike eh?
                I tried 3 different esc's on the gear drive boat and they all worked out without a hitch.
                • Diesel6401
                  Memento Vivere
                  • 4203
                  And Deisel that is almost exactly what I did one the gear drive.
                  Seems like your well on your way bud... Good luck!
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Killer V
                    6TH Season Builder/Racer
                    • 147
                    New idea
                    Hey Keith,
                    What school is your Father sending you to? Engineering, Rocket Science? Very good idea, keep them coming.
                    Killer V
                    • Jacked1
                      • Jun 2010
                      • 772
                      Thanks man! Now I just gotta figure out what boat to use?
                      • Jacked1
                        • Jun 2010
                        • 772
                        Originally posted by Killer V View Post
                        Hey Keith,
                        Killer V
                        Was that comment for me? haha and My name is Jared and thanks a ton if it was.
                        Ohio State for mechanical engineering
                        • timjz
                          • 271
                          Modern day version of the Great Planes Stinger SS! That boat had inline brushed motors & was also called the "Twinline".
                          Here's a thread on RCU with some pics:
                          Speed - Electric - GP Stinger SS and AQ Hammer same hull? - I've been out of the hobby for a couple of years, but recently I dug out my old Great Planes Stinger SS. It's an electric deep V with 2 inline motors which runs on two 6 or 7 cell packs. It hasn't seen the water for about 3 years. I went to AquaCraft's website
                          • keithbradley
                            • 3663
                            No, he was obviously talking to me, the smart one.
                            My name is Keith, but you're the engineer student...I thought for a second I could get fame just off of my name
                            • Jacked1
                              • Jun 2010
                              • 772
                              Originally posted by timjz View Post
                              Modern day version of the Great Planes Stinger SS! That boat had inline brushed motrs, called the "Twinline".
                              http://www.rcuniverse.com/forum/m_47...tm.htm#4773127
                              Oh yea! I remember that one! It was almost my first boat but I got the Villian instead.
