Dual Motors?
  • Matt is Back
    • 5
    Dual Motors?
    I have two stock AquaCraft Ep-1's. I need a ESC that can be setup to support 2 outboards on a 2 Channel radio. What do you guys have in mind?
    Thanks.
    • 5554
    Traxxas EVX marine will work..............................
    http://cgi.ebay.com/Traxxas-3020-EVX...item4cf2b9f730
    • Matt is Back
      • 5
      But the motor on the AquaCraft is a 27 turn. And the EVX 2 Marine has a limit of 19 turns. Will it still work?
        • 5554
        Yes.......the ESC can handle higher turns, not lower.
        • Matt is Back
          • 5
          My search is over. Thanks alot.
            • 5554
            One thing........the connectors for the EVX are made for a series connection. You have to mod then or close off one plug circuit and use just one............
            • Matt is Back
              • 5
              What do you mean? Instead of buying the new TRAXXAS batteries I should just mod the connectors so I can use the regular batteries I have.
                • 5554
                The connectors on the esc run the two batts that you hook up in series...........hook up two 6 cells and it becomes 12 cells etc............. If you want to run 6 cells close off one connector circuit and use one.........or then use a parallel connector to the open one and run twin 6 cells off of it....it works, i've done it.
                • Jesse J
                  scale FE enthusiast
                  • 7241
                  does it matter which lead you close off? or since it is series its all the same - did you try both and find it the same?
                  "Look good doin' it"
                  See the fleet
                  • Matt is Back
                    • 5
                    ok i get it. thanks
                      • 5554
                      One side works the bec...you need the other side closed
