The repair begins
I now have cut away the damaged side skins and have an intact rear that needs a new front.
The front sides are made and include a significant overlap of material, this will be beefed up with more internal strength and another outer layer of diagonally laid 1" wide strips of cedar and balsa in an alternating pattern to create a tiger strip pattern. This will give me a lot more strength in the front than before but in reality probably still not enough to survive an impact like the one that caused this damage in the first place.
My rationale here is that it was originally designed and built to take a blowover and a diagonal end over end cart wheel type accident and it had indeed survived both of those types of events. Now I will have more strength and a easier frame of mind when it goes back on the water.
Good points are that the esc plus external bec , Rx, and servo all survived !
I lost one of the two 1800mAh 3S packs but that is no major loss to the wallet and they were about to be made redundant with the new 6S pack on its way from HK
Here are a couple of progress pics.
