Pro Boat Mini Cat BL convert
  • Diegoboy
    • Mar 2007
    • 7443
    Here's a Pro Boat Mini cat that now has the following:
    Octura .098 flex shaft to 1/8 stub shaft
    Octura x430 prop
    Octura 1/8 to .098 flex hex coupler
    Ammo 28-35-2700 BL motor
    • Input Voltage: 11.1-18.5V
    • Max. Constant Current: 15A
    • Max. Surge Current: 30A
    CC Phoenix 25 ESC
    • 25A continuous current
    • 35A surge
    • 16 cells max with BEC disabled
    Rc Hydros PiStix Adapter <-- because the esc wouldn't program right on my JR XR3I
    E-flite S75 Sub Micro Servo
    Novak xxl FM RX
    11.1V 15C lipo
    Next warm enough day, she'll be tested!
  • Diegoboy
    • Mar 2007
    • 7443
    It's going to get the Micro Hydro HW when I get around to buying it. :blushing:
    • crazzy maxx
      • Dec 2007
      • 498
      it looks mean!! im thinking about buying my cuzing a mini cat for christmass.
      how do they preform out of the box??
      snort pixi sticks=symptoms-:
      • Diegoboy
        • Mar 2007
        • 7443
        Out of the box, they are slower than the Mini-V (not by much), but they are definitely more stable!
        • crazzy maxx
          • Dec 2007
          • 498
          well speed isnt a problem. im getting him a new motor.
          thanks for the answer
          brett
          • RCprince
            • Jul 2007
            • 1684
            We think alike Diegoboy, you just beat me to the punch.
            Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
            • SJFE
              • 4867
              Awesome man. Can't wait for the video.
              • Quicksilver
                • 226
                Originally posted by crazzy maxx View Post
                it looks mean!!
                thinking the same thing. Would think that prop would twist the boat right around
                BOATS CAN FLY AND SHOULD!
                • Diegoboy
                  • Mar 2007
                  • 7443
                  The x432 did cause torque roll in the mini-v, I don't expect the x430 to cause too much in this, but we'll see!
                  • Avanti
                    • 1298
                    Put on your wool hat & mittens and go run that boat. I can't wait to hear the results of your efforts.
                    The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                    • Tunda
                      Eh no steal my slipa
                      • 844
                      I just went on horizon hobbies and they dont have the proboat mini cat no more..
                      Whats up with that?
                      Hawaiian Tunda
                      • SJFE
                        • 4867
                        They have to change the name because of MiniCat racing. I don't know when the rerelice will be.
                        • Avanti
                          • 1298
                          there are a bunch on ebay, my LHS has a couple too. (I would buy one but I have enough projects for now)
                          • FE Wannabe
                            • Jul 2007
                            • 654
                            Diego,
                            A couple of questions:
                            Is that the stock stuffing tube on the "Mini Cat"? Because it looks like you have a teflon liner with your .098 flex cable, and I thought that the OD of the liner would be larger than the stuffing tube. I am asking because I am thinking about doing the same flex cable conversion on a Proboat Apache Cat, which also has the 1/8" straight shaft in it.
                            Also, what is the overall length of the Ocutura Flex Hex you are using? I am thinking I may have to change my motor mount to fit it in the Apache Cat.
                            Thanks for any info you can provide.
                            • Diegoboy
                              • Mar 2007
                              • 7443
                              Good observation! It is Not the stock stuffing tube. I pulled it out and inserted a 3/16 K&S brass tube (Stock #129)
                              As for the flex hex length, I can't measure it because Davey Jones has this boat now.
                              I made a typo in my build thread about the tube size... going to correct it now.
