Lets me start of buy saying I am going to over build this boat due to the fact I am going to punish it. I will be trying two different motors in this boat. I could not pass up the deals @ Castle and picked up a1520-1600kv and 1717-1580kv. I will be making the motor mount my self so to be able to hold both motors and see which one I like the best.
Planed setup
* 32” Df Cyber Storm (2 layers of extra fiberglass)
* 1520 and/or 1717 (1717 is 3oz heavier than the 1520)
* 6s1p and/or 6s2p (I like running smaller props higher rpm)
* Seaking T180 with external bec (will be adding caps and mod. water cooling)
* Flood Tube with .098 piano wire drive
* Jeff Wohlts Bearing Strut (mod. for more setback)
* Accu-Tech long trim tabs (mounted up 1/8” above bottom of hull)
* Small OSE turn fins
The first things I made a boat stand.
The boat stand was made also as a C.O.G. balancer.
Planed setup
incoming Larry, return fire!
