Another mean machine build?
  • forescott
    Hopelessly Addicted to RC
    • 3009
    Thanks for the tip. Will do!
    • dasboata
      • Dec 2010
      • 3972
      Did you set the boat up to a specific CG sure looks light in the nose I wish you the best of luck I sure want to see that vid Good luck Chris
      • forescott
        • 3009
        I try not to worry too much about cog. There is plenty of room for adjustment with the batteries in the sponsons. I'm at about 25% right now.
        • eboat
          • 726
          I was thinking the same thing
          My motor is mounted a little farther ahead with 1 4S on each side of the motor
          (old picture in my computer because it has a leopard in it now)
          • dasboata
            • Dec 2010
            • 3972
            And my build 30%-32 % CG I forget now LOL
            • eboat
              • 726
              I just checked my boat and I have put a magic marker line on the edge of the cowl opening at 9" from the back of the boat This is where my CG is and then I move the lipos ahead or back a little depending on the water of the day
              • dasboata
                • Dec 2010
                • 3972
                There is a pic of a Chris Fine build some where on here you need to check where he place his CG this is what I considered when I started my build !!!
                • forescott
                  • 3009
                  I was shooting for 27-30%.
                  • dasboata
                    • Dec 2010
                    • 3972
                    http://forums.offshoreelectrics.com/...pictureid=3917
                    • forescott
                      • 3009
                      Thats too far forward. And that hull originally had a 540 can, not a castle 1520. It was never run with that motor.
                      • ls1fst98
                        • 905
                        From everything I've seen and read on the MM you're gonna want to move those batteries farther forward. I placed me esc and batteries further forward than yours. I believe the mark is half way between the last step and second to last step. Looks good so far though, like the red carbon Kevlar
                        • forescott
                          • 3009
                          Got a great first run in this morning. This thing turns on a dime! Not a drop of water inside either. Got another chance to run this afternoon. Running real nice, had a spectacular blowover with a twist! Turns out my battery straps weren't tight enough and the batteries slid all the way to the back. YIKES!! I couldn't reach the boat with my fishing pole so I had to wait til it floated across to the other side of the pond. floated upside down for about 45 minutes. When I finally got to her she was as dry as a bone inside. Gonna run again tomorrow with my 2s 40c packs and the x-642.
                            • 9481
                            I don't think I went any further forward than 26-27% on mine and it ran great
                            • forescott
                              • 3009
                              I pushed the batteries forward to about 30% on my first run and you could definitely tell it was nose heavy. Could have been the prop I was using had a lot of lift too. I still have to get this thing dialed in before I run it with my 5s packs.
                              • dasboata
                                • Dec 2010
                                • 3972
                                What prop are you using ?
