Jeff do you have telfon i need also...................
Skunkworks gen 2 twin...........
I will look...not sure any more but.... I think McMaster has it.
2600kv x 4s
holly crud, this thing is going to be fast!
Nice build.I like this one.Its a little different and should haul pretty good.Your doing a fine job my friend.
Perfect hull size !! Love the struts, super strong ! Dieing to tell you the way I did the struts on the Quad.............. I ran the stuffing tubes 100% in and then backed them out enouph to counter sink the bushings into the strut about 1-1/2 mm. You will never be able to do this with ease if you don't sand your brass tube and then hit it again with some finer stuff. The best way to do that is to put your brass into a drill and not tighten it to tight, then pull the trigger on high and fold your snd paper and pinch the brass , king of like a lathe. Be carfull using steel wool , it will grabb and tweek your brass if not carfull. Do that untill you get your desiered fit . Greese and should go on and of great and will never back track water ! Also I run 3/8 o.d. octura thrust washers and minimal gap. .....about a thumbnail.... .... Sound like its going to be fast !
--Albert Einstein
watercooled motor mount 1 motor mounted and fitted, stuffing tube aligned ready for epoxy now..............
Last edited by bigpapa; 02-07-2011, 12:35 AM.THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
tks chuck two turnigy 2600 kv, 540's,2 turnigy 120 esc v2, 4s 5000 mah 30 c ,2 props u did for tracy 2 blade props u cut down to 45's lime green suck as my thunder tiger outlaw in my avatarLast edited by bigpapa; 01-10-2011, 12:16 AM.THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
think the esc is bad starts off flying for about 45 seconds and then seems to go to just about half throttle, gonna swap the 60amp out for a 120 and seeTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
but other than that lover it great hull just gotta find time to piddle with her..........THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
both mounts aligned and epoxed in place, progress progress progress
