A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
It originally had a SV-27 motor and speed controller and now has a XL9 on 4S LiPo with the SV controller, it runs in the low 40's consistently.
The pack is velcroed on to the radio hatch cover.
Originally it ran on 14 cells, 1 pack in the cockpit and one on the radio hatch. It was better balanced that way but with the single LiPo, its mutch faster. Be sure to waterproof your LiPos
OK I want it back now..............
sadly enough I am looking for another one, I realized that i want a hydro now.
how dumb is that? well good luck with the biuld man, I was thinking of a 4S 4350 or 5000mah right in the middle somewhere..........IDK
Eboat if that where my hull I would cut & section the top out of that hull. Making a larger hatch to work with. It wouldnt be easy but would make component and battery placment 100 times easer.
I cut out my motor mount and got it stuck in the boat with some 30 min epoxy
I drilled some holes in the base of the mount so the epoxy would work its way through
where I put the mount in the boat the bottom would flex very easily so I was going to add a layer of fiberglass over top to add some stiffness to it
When I mixed the epoxy I had extra so I just added it around the edge of my mount and it has stiffened up the bottom very well so I will leave it as is for now and see how it holds up
eboat, you will like the mod you are doing, keep on going,,,the snow will dissapear next week, I remember last winter, I was running the boats on the 3rd weekend of January,,,there has to be a few more days yet this year !
