Slick antenna trick
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Slick antenna trick
    If you've been frustrated by trying to thread a Rx antenna through the tiny antenna tube hole buried inside the hull ( I have ), try this : press the antenna tube nut into a small piece of wood that you've drilled a hole in-slightly undersized,with a vice using a little sticky stuff around the nut. Then glue this inside the hull ( I use JB Quick) lined up by screwing the tube into it once it's in place inside hull. Carefull not to get sticky stuff on the threads. When sticky stuff cures, push the Rx antenna through the MUCH LARGER hole, slide the tube down over it & screw into hull. Thought I'd share this while building a boat for my friend Naveed to race in Az.
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Thats a good idea.I might have to use this one on my next build.Smaller 32" cats are definitely a pain.Thanks for posting your trick.
