Here is what it used to be
The ose Slut Hull Build
I will really like to knowq how a a 2s lipo and a 2900 kv would move this, if it will be a waste of time I will sell it now the brushless sytem. I do have some 45 amp pb speed controls just need a motorLast edited by roadrashracing; 01-02-2011, 04:24 PM.
That was a nice run. I would like to see the setup on that boat.Originally posted by 785boats View PostWe've still got a few running at our club.
One with an 8XL on 4s & this one with the Ammo 2300.
http://www.youtube.com/watch?v=DHFClOixOWo
Wilmer and I had a OM26-N2 running at about 55MPH in oval trim. I have to pry it out of his hands every time I loan it to him.
With the right setup the OM29 can attain good high speeds. If you push out the strut more it will cause more lift, the one thing it does not need. For Oval speed one rudder and a shorter strut would be better. But this boat was setup for LSO and it takes a bit to change.
I guess I would be intested in flood chamber looks pretty coll and no need to recover every time it flips. What is lso?
with the setup I am going to run should I keep the motor where it is or bring more in on the hull and have batteries on ether side?
Limited Sport OffShore=LSO
That video was when I first got it.Originally posted by roadrashracing View Postfound a nice video, man there is a lot on this boat, think I should keep the yellow?
http://www.vimeo.com/9124030
Find out The setup from 785 boats because that's the OM was dialed.If all of your wishes are granted, many of your dreams will be destroyed!
Use a heat gun to help soften and weaken the epoxy.Once its pretty warm,it should pop right out.
drive sytem is all set, got motor mounted, I think I used a wrong king of stuffing tube, I used 7.32 tube by mistake, is there any liners that fit in it, or do I just need to pack it with grease?
Do I just need turn fins on the back or do I need sablizers to? I was this thinking of cutting some angle for that.
do not bother with a liner...just make sure you grease regularly...turn fins are usually recommended on monos to take advantage of full turning...trim tabs are an experimental thing..you can try the boat without them first..if you are getting alot of unwanted bouncing or rocking from side to side after moving batteries and adjusting the drive..then you could try tabs..they are not a total necessity kind of depends on the hull"FE" STANDS FOR FRUSTRATING EXPLOSIONS
