yea man they fit in their like butter i mean perfect fit lol i couldnt get any better they fit so good you dont even need a strap but i will just for safety sounds good i wont have to buy higher mah packs shew..
help delta force 35 hardware install
You only need higher mah packs when your C ratting is lower. your discharge rate is what is most important in combination with mah. A good rule of thumb is have batteries that never go over 70% of there limit, they will last longer and not send voltage spikes to your esc. A single 5000mah 40-50C can give you 200 continuos amps but your setup should not draw more than 140 amps....that is if you are concerned with stressing your battery and the capaciters on your esc.. I learned this stuff the hard way................Originally posted by Taylor View Postyea man they fit in their like butter i mean perfect fit lol i couldnt get any better they fit so good you dont even need a strap but i will just for safety sounds good i wont have to buy higher mah packs shew..
--Albert Einstein
Hello
Checkout mine DF 35 in the Offshoreelectrics forum and you can have an idea..running low sixties...with NEU1527 1.5D
Best Regards
http://forums.offshoreelectrics.com/...highlight=DF35
