Properchopper's Herb Stewart Tunnel Hull build
  • RandyatBBY
    • 3943
    Looking cool Tony
    Randy
    BBY Racing
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      Very nice Tony.
      • Chuck E Cheese
        • 2136
        yep, i sent it to danny for you. she saw quite a bit of action on a sv set here.. it was my experimental tunnel. i wasnt convinced that the motor would not short out in the salt water
        chopper - watch out with the wires coming straight up through the alum tubes. make sure you have plenty slack there. i burned up a 1515 because over time the wire shield got gouged from turning back and forth. it shorted out on the brass tube i was using and pooffff.
        otherwise that is a great looking build (as are all of yours)
        • rearwheelin
          • 2101
          What a great job Toney , that truelly is a good job. Sorry to bother you with me dumb servo question...lol
          --Albert Einstein
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Thanks, Ryan. Should be a good boat. And yup, I did get her wet at Joe's yesterday. He may post a short vid. Short, because, while all signs indicated a nice handling rig with great potential, the motor wires on the old test motor had too radical a bend to duck under the canopy and I was encouraged by the one lap I did, and have some more motors (UL-1's) on the way.
            Stay tuned
            Here's the short vid. Smallish test prop / speed will be bumped up [hopefully]when tuning resumes with new (spec) motor. Likely will not end up as fast as the VS-1's and others, but the plan is to out-survive smaller/faster boats in racewater. THEN with a P-class SAW setup it should really rock.
            • Monstermanhbf
              TheQuadGuy
              • Dec 2010
              • 9
              Looking good properchopper!
              Chris
              https://www.facebook.com/MonstermanHBF
                • 9481
                http://www.youtube.com/watch?v=LqdX5gK0pKo&
                that looks fast to me!
                • marko500
                  • 862
                  Tony, on the T-180 ESC which 90 degree water fittings from Kintec did you use. Also do the old ones pull out or are they threaded? This might be just the solution for fitting that ESC in my hydro better. Your boat looks great! A tunnel is definitely on my future build list.
                  Mark
                  • properchopper
                    • 7708
                    Mark
                    Mark,
                    On the Kintec site, click cooling, scroll down to the "Banjo fittings". The stock ones unscrew-I used a vice grip. The banjoes thread right in, can be pointed in any direction & tightened. O-rings are included. Very slick deal. I fully expect to have a parade in my honor for coming up with this mod
                    Before you start a tunnel build, make sure your medical insurance includes in-patient psychiatric care - they can be that frustrating to build
                    • Doug Smock
                      • 5359
                      Nice work Tony! Ole Herb would be proud of that!!
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • properchopper
                        • 7708
                        Doug
                        Thanks, Doug. I'd like to add another trophy to his legacy when the SAWs come around
                        • marko500
                          • 862
                          Tony, your idea on the 90 degree fittings on the T180 esc works like a champ! I had a couple fittings in my toolbox that worked. So here's your parade-
                          Mark
                          • BILL OXIDEAN
                            • Sep 2008
                            • 1561
                            Hey Big boy, didn't know you were so good with your hands..
                            Nice Tunnel build buddy sweet paint scheme..
