ABC FIGHTER 550 brushless motor ?
  • SweetZ28
    • 1535
    Hi guy's for some reason i always liked my ABC fighter 550 boat and now i decided to make it brushless Here is the motor i am going to put in the boat and run on 2S do you think this will be good enough for this boat?
    I know they are the small 380 sized motors in a 540 size can and i do have a 3300KV motor the same type but run it on 3s in my apatche 24 and it works well so i figure the extra KV will make the smaller 550 boat work pretty good.
    what do you guy's think?
    Specification:
    Watt: 400
    No-Load Current: 2.1A
    Load Current: 41A
    No-Load RPM: 5W
    Load RPM: 3.75W
    Weight (g): 170
    Diameter (mm): 35.8
    Length (mm): 50 (Without Shaft)
    Shaft Diameter (mm) 3.17
    WWW.PPRSLOTS.COM
  • FRED
    • Jul 2007
    • 232
    Now if memory serves me right, the 550 hull can only go so fast and above that is a waste of time. There were alot of boaters who have tried back about 10 years ago by using Trinity Chameleon Motor # 2122 and had to fall back on a lower rpm motor. I had those brushed motors with a long armature and they did great . Too much for a 550. Anything over 20 mph turned sour. They weren't designed for much upgrades to increase speed. That motor would work in the DF 23's on 2s due to light weight and shallow vee.
    • SweetZ28
      • 1535
      Geuss no one likes the Fighter 550!
      WWW.PPRSLOTS.COM
        • 9481
        give it a whirl bro, and let us know how it goes
        • SweetZ28
          • 1535
          Thanks Brushless i will.
          I can always count on you for help!
          I am getting the motor in soon but i can't run it everything is frozen over here!!!
          THANKS
          WWW.PPRSLOTS.COM
            • 9481
            Yeah I actualy thought about getting the new Traxxas boat to kick around but things are starting to freeze up
            • SweetZ28
              • 1535
              yea in NJ it's all ice!! I got a widow maker 22 this year in the swap shop i got to run it once and i got to get that thing tuned also it hops wiggles side to side in the turns it can't take a turn for crap!!
              My fleet now
              brushless Mini offshore worrior
              brushless apache 24
              SV 27
              Brushless mini alligator tours
              Widow maker 22
              Soon to be brushless fighter 550!
              WWW.PPRSLOTS.COM
                • 9481
                Sweet..!
                Keep us posted on how that motor works
                • SweetZ28
                  • 1535
                  Will do
                  WWW.PPRSLOTS.COM
                  • Alexgar
                    • Aug 2009
                    • 3701
                    ive been trying to pick one up to bl it to but ebay always bids to high for these
                    • SweetZ28
                      • 1535
                      Yea never looked on E-bay that stinks ... I like this little boat.
                      Hey Brushless I put the stuff in that tacon motor sounds fast! I used my watt meter on a 7.2V pack it pulls just over 8 amps free load with prop on in the air my widdow maker pulls a little over 9 amps but sounds like less RPM ...will have to do some testing... in a few months when the lake is not frozen!
                      WWW.PPRSLOTS.COM
                        • 9481
                        that's a sweet looking hull man!
                        what radio are you using?
                        • SweetZ28
                          • 1535
                          Thanks
                          The radio is a flysky GT3B 2.4 with hopping and 10 model memory
                          WWW.PPRSLOTS.COM
                          • SweetZ28
                            • 1535
                            Here is what it looks like but without the green grip.
                            WWW.PPRSLOTS.COM
                              • 9481
                              I've thought about trying one of those, and there not all that much
