Hello Guys,
as there seems to be some interest, I'll start the building review of a HPR06 also here on OSE. I hope you enjoy. Beside this, where would be a good place here to introduce myself and tell a bit about me and my hobbies?
HPR06 - Austrian Build
Beside building my "Fort-Knox" (nice expression Gerwin) I'll also build a HPR06 for season 2011. With my Repsol I have already a HPR06 so a second one is not necessary. Only Hanspeters new C5009 Mystic would be worth a try...
So the HPR06 in this review is a remittance work, which I'll do for my friend Wolfgang. He has seen our boats on our homepage as well as on Youtube and wanted one. Thats why I should build this HPR06 completely RTR including testing and finding the right setup for the boat. The choice of the setup is mine, the demand is to reach about 120km/h (75mph). Its not intended to be a highspeed model, scale look and reliability are more important.
Therefore it will also include a second hatch with the cockpit glasses for the glass cabinet as well as some pilots inside the cockpit. Surely the boat will also get a nice paint job, maybe with some airbrush.
Setup
hull: HPR06 in CFK (carbon/fibre - newest Version)
hardware: original HPR hardware including hydraulic steering
engines: 2x Tenshock 2250/7 with WK
ESC: 2x 180A Seaking/Turnigy with aditional caps
lipos: 2x 6S Turnigy 4000mAh 40C
props: pair of Octura X442 to Octura X447
speed: personal aim is to reach 130km/h (81mph)
transmitter: Futaba T3PM 2.4GHz mit FASST
miscellaneous: lipo-rail-system, CFK-motor mounts, CFK-servo mount, Notaus, 5mm Flex-Wire v. Gundert, 6mm LMT-bullets (best in the world I think), bolted hatch, div. scale parts
hull
As mentioned the hull is a HPR 115 in carbon/fibre. Hanspeter has again improved some parts of the laminate, this hull is the up-to-date version, beside being a "default-laminat" if you can say that to his hulls. The seam as well as the finish are crafted beautifully. As with all of my hulls it had to prove itself on the scale. The hull has 1975g, the hatch 275g --> makes altogether 2250g or 4.5pounds. Its not an ultralight hull but a normal carbon/fibre hull with reasonably weight and exceptional stiffness.
Here some pictures:
Setup
hull
Here some pictures:
