chuds befu mini mystic 3
  • dano1
    • Dec 2010
    • 439
    #76
    Let me know mr -t how that goes, i'll do it to mine also
    • CHUD
      • 554
      #77
      _Sign:
      Thank you!
      I may try that clear over the Genesis I just picked up in the swap shop to help protect the paint job and deepen the look
      My brother 'S MISS GEICO has been cleared 5 times with the Lacquer vary nice!! But be out side and ware a mask vary strong ,and vary vary light wetsand after the 2 coat, Hydrojerry also is going to do his Genesis ,the clear is coming off!!
      • CHUD
        • 554
        #78
        dano1
        Thanks for stopping by dano take a look at my brothers geico at the top of the page its sprayed 5 times and my longlite 1 time , You might spend a few day's on it but it dry's in 30min I shot mine at 57 outside, and you can put some more decals on and respray at anytime!! good Luck
        • monojeff
          • Nov 2010
          • 2728
          #79
          Put at least 5 full coats on & lightly color sand then buff & it should be really smooth & shiny!!!
          Plus no one will even be able to tell they are decals if you build it up enough....
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
            • 9481
            #80
            _Sign:
            Good to know
            now is there a trick to it, because I used Krylon clear before on my MV and it had some milky spots on the hull in a few places
            • HYDROJERRY
              • Jan 2010
              • 2709
              #81
              Iused to use Krylon and it always screwed my boats up,,cracks or blemishes or something always, so i switched and tryed alittle of everything and so far for me the spray can lacqur worked great and i also got some auto shop clear and used a spray gun and the spray can laqcur still did better for me!!!!!dont no how durable or how long it will last yet cuz my miss G was my first one so.....
                • 9481
                #82
                you using the same stuff posted in the picture
                • HYDROJERRY
                  • Jan 2010
                  • 2709
                  #83
                  Yep thats it i used it before chud and he thought it looked so good in person he went and got some so thats two of us using it!!!!! The paint on my mini-G felt like the skin on a basket ball (all bumpy,like billions of little dots) after about 3 coats it got smooth with no sanding then i did a wet sand and shot it 2 more times in the same day and it was good but i keep adding stickers so now i gotta do it again!!!! gotta stop adding stickers,,,
                    • 9481
                    #84
                    Sweet!
                    not to jack this thread... did you scuff the paint before spraying clear, and what grit did you color sand with?
                    I should have a Genesis hull in a couple days I want to try this on
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      #85
                      I did not originally scuff it cuz after many tries with the neon yellow it would cut threw in the corners so my first coat was light on top of the neon but yes i recomend you scuff your first,, i did use some wet/dry sand paper like 3 or 400 grit but not sure ill look when i get home tonight and find out for sure dude..
                      • CHUD
                        • 554
                        #86
                        Sweet!
                        Preparation/Lightly sand glossy surfaces /clean with soap and water/rinse and let dry/ This is on the back of the can brushless and I would use a vary fine grite and wet sand,Your Genesis if it's already cleared, I'm going to test this out on my green sv27 hach this weekend if it get's over 50 F and I will give you a heads up!!! But when I did the longlite I dident sand the paint only after the secound coat of Lacquer/ Hope this helps bud!!
                        • CHUD
                          • 554
                          #87
                          3 good coats
                          You guy's can really see the clear in these after 3 good coats /I'm sold/and just take in MONOJEFF WORK SWEET /I need a new avetar
                          • dana
                            • Mar 2010
                            • 3660
                            #88
                            i like what you've done with the white one. i may just do my mean machine like that
                            • CHUD
                              • 554
                              #89
                              hay dana
                              Thanks for stopping by bud,MONOJEFF got this one right man if you need something done drop him a line ,keep Rockin!!
                              • old guy
                                • 710
                                #90
                                does Befu make this little cat?? I have a new rudder that needs a home on a small twin cat
                                old Guy
