MHZ Mystic C5000 M 114cm (44.8")
  • domp444
    • Jul 2009
    • 901
    Got some more done. Cut out the holes above the drives. The large ones were good practice for when I cut out the holes for the drives. I'm also gonna get some longer screws, since they barely go through the hull (for the mounts above the drives).
    • johnf
      • Dec 2009
      • 1086
      Looks good.
      Catching Air!
      • domp444
        • Jul 2009
        • 901
        Originally posted by johnf View Post
        Looks good.
        Thanks!
        • domp444
          • Jul 2009
          • 901
          Finally drilled one of the big holes for the drives. Phew, that was scary.
          • domp444
            • Jul 2009
            • 901
            #35
            Got the other one done as well. So now all that's left for the drives are the mounts that go on top of them :)
            • domp444
              • Jul 2009
              • 901
              #36
              Got the rudder done today. The hydraulic mockups came out a little uneven but I'll sort that out tomorrow. Other than it I'm happy with it. It was really hard to get the 6 holes for the rudder mount lined up and they came out larger than I planned. I finally got them to go through though and that was a big relief
              • domp444
                • Jul 2009
                • 901
                #37
                I finally got some longer screws. I also put one longer screw in each drive mount where the reinforced plate thing is. Now I'm waiting for my flex stuff to come in from MHZ, then I'll be able to cut out the water intakes.
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  #38
                  "Look good doin' it"
                  See the fleet
                  • domp444
                    • Jul 2009
                    • 901
                    #39
                    My lipos came in yesterday
                    Hyperion:
                    2x 6s G3 EX 5000mah 45-90c
                    2x 5s G3 EX 5000mah 45-90c
                    1x 2100mah LiFePO4
                    • Anbjorn
                      • Apr 2009
                      • 255
                      #40
                      Good choice of batteries
                      Anbjørn
                      • domp444
                        • Jul 2009
                        • 901
                        #41
                        Anbjørn
                        Thank you
                        • SANTAVY1
                          • Jan 2011
                          • 212
                          #42
                          Looks like the build is comming along nicely. I agree water pickups should go as close to center as possible. What type of pickups are you going to use, the mhz style? I used aluminum tube which allowed me to get tight against the sponson and still miss my shaft tubing. It also allowed me to protrude out of the hull more for better water flow.
                          • domp444
                            • Jul 2009
                            • 901
                            #43
                            Yep, I am waiting for my flex cable stuff to come in so that I can see how close I can install the pickups. I have the MHZ ones, which I am planning on using. I like what you did though! It really allows you to get right up into the side. I'm gonna have to grind out some of the carbon/kevlar like I had to when installing the drives in order to get them really tight to the side.
