HELP FINDING 5mm x 3/16 SQUARE COUPLER
  • mm123521
    • 193
    Help! Where can I find a 5MM X 3/16 square drive motor coupler?
    I need to connect a Castle 1518 motor (with a 5MM motor shaft) to the square end of a .187 (3/16 inch) flex cable.
    Thanks!!
    Mark
    Avatar is the dangerous end of a Gatling Gun!
    Good luck. Very few run square drives in FE boats. A few may be available for an OB setup. Why not a flex hex collet?
    • mm123521
      • 193
      Fluid:
      Ok, if you don't run a square drive, then how do you take the thrust?
      In the gassers we took the thrust on the strut using thrust washers and the "wind up" length difference was taken up in the square drive coupling.
      Help!
      Mark
      • carlcisneros
        • Jan 2010
        • 1237
        You will more than likely have to buy 2 flex couplers from aeromarine. (Or at least ons regular
        flex coupler and a square drive insert from them.)
        www.aeromarinerc.com
        Carl
        • mm123521
          • 193
          Thanks Carl -- I see the 3/16 square inserts.
          I'll call them tomorrow and see if they have the 5mm end.
          Mark
            Most FE racers take the thrust on the motor, the bearings on quality motors are designed for it, on lesser motors a separate thrust bearing is used. I've taken the thrust at both places in the same boats and I couldn't see a difference in the boats' handling or attitude. If you do the vector analysis you'd see why.
            Square drives are just not used except for FE outboards. Do yourself a favor and don't try to reinvent the wheel here. Use a standard collet like everyone else does.
            • mm123521
              • 193
              Fluid:
              I guess I'll have to use the hex flex - round, because nobody has the square drive!
              Thanks
              Mark
              (vector analysis - I can do that!)
              • Punisher 67
                Ignore list member #67
                • 1616
                If they had a 3/16 square I would myself personaly use it , with the larger 4 foot boats and the 1/4 square flex I have had extreemly good luck with it , 3 seasons with a Lehner 3080 and Neu 2230 and not one single issue . on mine the square end is in the strut
                • mm123521
                  • 193
                  Punisher 67:
                  Thanks for the reply.
                  I couldn't find 3/16 square drive couplers anywhere, so I built my own (see pictures). I have a small machine shop in my basement, so I can build custom stuff. A pair of these couplers was a 4 hour project.
                  Look at the pictures of my motor mount. It is a water cooling jacket and motor mount. It just fits inside the sponsoon and will bolt to the outside of the rail. I still need to tap the water fittings in. It will mount the motor without using any fiberglass, so it will be easy to change drive configurations later. It took all day Saturday to build the motor mount, today I'll build the second one.
                  Oh, by the way, thats the new SprintCat in the pictures. It arrived on friday. It took Areomarine about 8 days to build and deliver this 34 inch hull. Hull looks good, "Classic" hatch fits well.
                  I was happy to see that the batteries and motor will both fit inside the sponsoon. That configuration will keep the vertical center of gravity very low and maybe keep it from rolling over in a hard turn? It looks like there is room to mount the batteries over the drive line, I gotta see.
                  The struts, in the picture are also home built, but I am undecided as to whether to use them. I keep thinking of buildig a "stinger" type strut. What I am thinking of would be non adjustable for angle, but have a small adjustable height. I wonder if the hull will plane correctly without an angular adjustment???? Help on this one!!!! The stingers would look better and I know that I could make them more water tight than the struts.
                  Mark
                  • chummer
                    • 650
                    Where's the pics?
                    "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                    • mm123521
                      • 193
                      Chummer:
                      Had trouble gettting the pix up.
                      I think they were too big, had to retake them at a lower resolution.
                      • Punisher 67
                        • 1616
                        Very nice Mark
                        I have a small machine shop in the basement myself which includes a CNC Mill and Lathe . handy isn't it...................
                        • mm123521
                          • 193
                          Punisher 67:
                          For me, thats 1/2 of the hobby - making custom parts.
                          Is that you making the motor mounts for everyone??
                          CNC !!! Wow !!
                          I just have a manual mill/ drill that I have put A LOT of miles on.
                          Got two small lathes (one is a Craftsman 12 inch), vertacle saw, horizonal saw, surface grinder, tool grinder, rotary table, indexing head, etc
                          I built two, 22 caliber, 10 barrel, gatling guns using the above equipment. http://www.youtube.com/watch?v=WhVavTvlvjg
                          I also build extreme powerfull airguns (I have one that is more powerfull than a .357 magnum).
                          Someday I'll get CNC - when I get rich!! lol!
                          Mark
                          • Punisher 67
                            • 1616
                            yes thats me.....The mount guy........
                            You can get a fully CNC'd Taig Mill with a 4th Axis for under $2500.00 through Deepgrove1 on Ebay , Then buy a refurbisher pentium 4 through any of the many suppliers out there . My computor was under $200.00 to my door . and finally the Mach3 Cam program to run the whole show for $175.00 .
                            The possibilities are now limitless to the goodies you can make and sell and best part of all make for yourself
                            I agree for me the build is the exciting part , running the boat is just the icing on the cake
                            Mark that gatling gun is way coool............................................. ......
                            • mm123521
                              • 193
                              Punisher :
                              Beautfull setup!!
                              How hard is it to setup and debug a programm??
                              Something like to build a motor mount??
                              For one-at-a-time parts (not to be duplicated), is it worth the time developing the programm?
                              Are those "teach Pendants" I see in the pictures??
                              My shop is 1/2 inch deep in chips, most all the time!!
                              Sounds like it would take $3500 to get set up?
                              Your lathe is CNC'ed too???
                              Thats a good looking rotary head on the left side of your table.
                              Mark
