Spec Miss Vegas build
  • Hydromaniac
    • 955
    #46
    Originally posted by wparsons View Post
    If you actually plan to race it, check what people at local clubs have for classes. Just because it's in the NAMBA rules doesn't mean local clubs follow it exactly.
    The last thing you want to do is build it one way only to show up at a race and find out you can't race because it doesn't match their "spec" requirements.
    Thats how we run our "Spec" classes, Only certain motors are allowed. They are the same motors that are recognized by most clubs around the country and pretty much the same that were ran at the FE nats. We have built a very strong "spec" program that works well.
    www.rockymountainthunderboats.org
    • wparsons
      • 461
      #47
      Originally posted by Brushlessracev View Post
      Still run it with the specs not going to be any faster then a stock UL-1
      Faster or not, if the motor isn't on the allowed list, you can't race.
      Light travels faster than sound, so people may appear to be bright until you hear them speak.
      • Hydromaniac
        • 955
        #48
        BINGO!!
        • Brushlessracev
          • Oct 2010
          • 154
          #49
          whats on the allowed list. I can always swap motors its not like its set in stone anyway. what speed controllers are you allowing.
          • Hydromaniac
            • 955
            #50
            The same ones I e-mailed you in the past.
            NO LIMIT ON ESC
            Allowed motors are:
            AQUACRAFT SV-27 BOTH VERSIONS
            AQUACRAFT UL-1 2030 KV
            PRO BOAT BLACK JACK-26 1500 KV
            • Brushlessracev
              • Oct 2010
              • 154
              #51
              NO LIMIT ON ESC
              Allowed motors are:
              I did not know that was you, thanks, you are RMTB in Pueblo. Thats cool. I have a aquacraft 2030.
              • Hydromaniac
                • 955
                #52
                Yep the same club that you have been asking about racing with. Good luck with your build.
                • Brushlessracev
                  • Oct 2010
                  • 154
                  #53
                  Its almost Done waiting for motor, water jacket and turn fin from Australia. and servo from Tower.
                  • Rottenbelly
                    Captian Big Nerd !!
                    • 89
                    #54
                    Nice build!! I accuired one of these boats from a member on here.
                    Looking at motor options for a little more speed. But on its first run it was a great running/ handling boat.
                    Looking forward to seeing how yours turns out.
                    My work boat has 12,000 HP!!!
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      #55
                      looks great man,, what no clear plexiglass???? just playin!!
                      • Brushlessracev
                        • Oct 2010
                        • 154
                        #56
                        LOL, na i decided to seal the hatch then tap it. the plexiglass thing works too.
                        • HYDROJERRY
                          • Jan 2010
                          • 2709
                          #57
                          I no when i tape my Miss Elam the curves suck !!!!
                          • Rottenbelly
                            Captian Big Nerd !!
                            • 89
                            #58
                            How does yall's do with taking on water??
                            I have the plexiglass cover siliconed partways, Then i tape the front AND tape the hatch cover and it still takes on alot of water.
                            Its good to know that my Castle 120 will run underwater!!
                            • Brushlessracev
                              • Oct 2010
                              • 154
                              #59
                              Did you cut the nose off yours too and attach it to the hull. thats is what i did you might be getting water from else where check your turn fin mounting i epoxied mine to the hull with the screws to seal it. same with the rudder and strut.
                              • Rottenbelly
                                Captian Big Nerd !!
                                • 89
                                #60
                                Thanks for the info. I put it in the tub again to see.
                                I do see a small spot starting back by the rudder.
                                My nose is cut off and epoxied. Mine just submarines so bad when i take off....
                                got a new motor on the way to see if that will help get it moving a little better.
