Nitro Lapcat conversion
  • RandyatBBY
    • 3944
    I have a 36 inch Prather Lapcat that am going to convert to Lipo. I am thinking a 6S2P, a Large Neu motor and a Schultz 40.160. This is the boat I have to start with.
    Business end to be removed and sold. I will machine the outdrive to accept the Big Neu Motor.
    Uploaded with ImageShack.us
    Randy
    BBY Racing
  • RandyatBBY
    • 3944
    Just so you guys get a idea how big this boat is I put a UL-1 motor on the out drive.
    I stripped out the radio box to prepair for the el; electric setup.
    Randy
    BBY Racing
    • RandyatBBY
      • 3944
      I will be machining the outdrives tomorrow.
      Randy
      BBY Racing
      • RandyatBBY
        • 3944
        Started to machine the 11cc lower 1/2. It has a much diferant shaft profile and needs to be build a lot different than the 3.5. Several more parts are necessary. Done to this point.
        Randy
        BBY Racing
        • F1 madness
          • Feb 2010
          • 788
          Looking good,i do like the retro look.
          will be watching
          http://s577.photobucket.com/albums/s...79/F1%20boats/
          Daz from sunny England
          • RandyatBBY
            • 3944
            Well got a little more done on the OPC.
            Randy
            BBY Racing
            • RandyatBBY
              • 3944
              Mount for the servo is done. Well rough out I still need to get the servo to make it fit correct.
              Randy
              BBY Racing
              • RandyatBBY
                • 3944
                I really did not like the way I had this out drive set up to remove the motor screws. I machined some access slots to slide the screws up from the bottom now I am happy with the way it works. I also put on the water cooler and I will add end cap screws now.
                Randy
                BBY Racing
                • RandyatBBY
                  • 3944
                  Made good progress on the hatch, Push Pull rods next.
                  Hatch lid fitted
                  Randy
                  BBY Racing
                  • RandyatBBY
                    • 3944
                    Getting tired about done for the night.
                    Randy
                    BBY Racing
                    • HOTWATER
                      • 2419
                      Nice Randy! I like it!!! The lower looks really good polished up...are you going to be using a cav. plate? Where will the water pickup be located? Also, does it have the original turn fin on the bottom of the right sponson? (just curious, that's all)....
                      Cool bro!
                      -Kent
                      "Will race for cookies!"
                      IMPBA D12
                      • RandyatBBY
                        • 3944
                        Cool bro!
                        -Kent
                        Thanks I never use Cav plates they slow the boat down and restrict the size of the prop. Water pickup in next photo. Yes they deigned the boat to work best with the turn fin so I am leaving it. I have removed them before and had to put it back no the boat.
                        first two packs go in under the deck one on each side.
                        Randy
                        BBY Racing
                        • RandyatBBY
                          • 3944
                          A picture for the owner of the boat to see how to make 8S2P he is learning sort of a newbe. One note I was told not to pull on wires when the batteries are hot. they will disconnect internally and that is bad news. Also running a ESC at 1/2 power for prolonged times is bad. Full throttle or off is best. The Schultz is best of any controller I have used but still I like to be cautious.
                          Randy
                          BBY Racing
                          • RandyatBBY
                            • 3944
                            Well it is getting close to first start up and take to the pond and test.
                            Randy
                            BBY Racing
                            • F1 madness
                              • Feb 2010
                              • 788
                              hey randy
                              Looking good,will we get a vid of how its performing
                              Rgds F1
