Ultra fast electric options
  • hyrulejedi86
    • Aug 2009
    • 500
    I was looking through the hulls here on OSE and started thinking it would be awesome if I could build a very fast electric boat sometime but just not yet. I want to start planning it though.
    So here is my question:
    While keeping things reasonably priced (not $500 hulls) what would be a couple examples of good hulls to use for this application? I was thinking 65-75mph range.
    What kinds of hulls, specific examples, sizes etc? I welcome all good information for my panning purposes.
    Cheers!
  • carlcisneros
    • Jan 2010
    • 1237
    JAE outriggers are one boat to look at.
    Carl
    • Rumdog
      • 6667
      Do you want a SAW type rig, or one that will run well in an oval?
      • electric
        • 1973
        Insane FE 30 will get you into the low 60's without to much trouble and at a reasonable price.
        • hyrulejedi86
          • Aug 2009
          • 500
          Hmmmm, I was thinking something that will allow you to run in an oval.
          Good suggestions so far! Just based on what's been said and what I said would a feigao xl size be required or the even bigger size one? I just mention feiago because I like those motors.
          • Rumdog
            • 6667
            Not a Feigao. Not to run the speeds you want reliably. What kind of budget are we talking here, total?
            • LarrysDrifter
              Big Booty Daddy
              • 3416
              Feigaos run decent,but are two pole.Go to lightflightrc.com and look at the Arc motors.They are 4 pole and are very dependable and if the motor ever quits working for any reason,you send it back to them and give them $35,and they send you a new motor.You can run a motor mount screw too far into it and do the above and youll still get a new replacement.Leopards are good running motors too.I just ran mine and am very impressed.For hulls,if you like cats,FighterCat57 is having cats made that might be worth a look too.They arent MHZ or H&M,but they might suit your needs.Obviously,a rigger or hydro will turn a lot better.Just go with what you like and what will suit your needs.
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                I tried to link this www.lightflightrc.com. Maybe itll work this time.
                • hyrulejedi86
                  • Aug 2009
                  • 500
                  Well, as for budget since this is only planning I don't have one. If nothing else I want to know what it really takes to hit those speeds. To learn how to make a good boat and what to look for.
                  • Rumdog
                    • 6667
                    THE best hull I've ever owned is the Aeromarine Sprintcat .40. It is a 34.5" cat. It will eat up the chop, and make WOT turns at 60 plus mph. It will hit low 60's with a 1527 on 6s. You could also use an outrunner to save some cash, or a castle/Neu 1717 would do pretty well. The hulls are in the 250 range I believe.
                    • Rumdog
                      • 6667
                      It WILL turn as good or better than most hydros or riggers, and in both directions!
                      • hyrulejedi86
                        • Aug 2009
                        • 500
                        I will definitely take a look a the hulls tomorrow after I get out of clinic and the arc motors look really nice but I couldn't find watt rating or a voltage rating or an amp rating. Maybe I just missed it but I didn't see those stats.
                        • Rumdog
                          • 6667
                          Vid of mine running twin 1515's. Just so you can see how they handle big speed! http://forums.offshoreelectrics.com/...ad.php?t=14659
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            Man, Rum...........everytime i watch that vid, the hair on my neck stands up...............it looks so solid and the sound is the best i have ever heard from a twin..............awesome.
                            • oscarel
                              • Dec 2009
                              • 2373
                              Sprintcat with twin $70 castle 1520 or 1717
