New toy cat
  • F1 madness
    • Feb 2010
    • 788
    Originally posted by LarrysDrifter View Post
    Your cat is pretty well the same as a junker EKOS.Look at the EKOS threads and youll get some good ideas and pics to refer too.I know your not an newbie just throwing stuff out there.I just re-built my EKOS for the 2nd time.Look at the SeaKing 120 thread.Also,if you have the degree increments marked on the stingers,they arent accurate so,youll have to measure.
    yeah that was mentioned earlier in the thread,i'll have a butchers at the thread will be some help to see what others are doing,i did notice the angles werent true LOL while i was checking everything over and adding some thread lock on grub screws etc
    Thanks bud
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      Your welcome.Good luck with it.They are fun boats,just a pain sometimes.I dumped too much money into it to get it where it is and its still just a cheap hull.Lesson learned.
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3480
        Heh... and most recently, if you submarine it, the windows will blow out and the hull fill with water. Chummer discovered this weakness...
        • F1 madness
          • Feb 2010
          • 788
          Oops will have to watch what im doing then LOL,could always make a new cowl minus the window cut outs mmmmmmmm
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3480
            Think re-enforcing it will help mitigate the risk. But yeah, it was alarming. I still have a build in the works.
            • bigpapa
              • Apr 2009
              • 2330
              Nice I will pm u later
              THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
              CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
              • bigpapa
                • Apr 2009
                • 2330
                We need to talk
                • tiqueman
                  • Jul 2009
                  • 5669
                  What company is labeling this one?
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3480
                    This one's available right from Dragon hobbies.
                    • chummer
                      • 636
                      Yep, it's true...a good nose dive and the windsheild removes itself completely from the hatch. When it resurfaces you will ask yourself.... "Why is my boat driving itself around in circles and won't respond to my transmitter"?
                      You will then notice how the water line on your hull is slowly getting higher.
                      As you try to run through water (if you have ever tried this before you know how difficult it can be) to save your hard earned dollars, it will start to let out this magic smoke through the now huge opening where there used to be a windsheild. It looks really cool with all that smoke coming off the water. But don't worry too much..... eventually the hull will fill with enough water to put out the fire. And the best part,,, it will leave a strange odour in your hull that seems to never go away! I am getting all to familiar with that smell.LOL
                      But wait.....there's hope.
                      The windsheild removed itself from the hatch and was able to be glued back in. I'm not experienced with cloths and resins but I do have a freind that is.. He added carbon fibre on the inside of the hatch to reinforce the windsheild. Looks killer. I had him do this to my new EKOS hull as well just to be safe.
                      He also gave my new hull a nice shiny coat of clear. This will help keep the decals from peeling off. That is another problem with the EKOS hull.
                      Here's a few pics of the new hull.
                      "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        Nice!
                        BTW- wax will help prevent the tape from sticking too much, but still care should be used every time to ensure the paint stays put.
                        • F1 madness
                          • Feb 2010
                          • 788
                          Hey chummer,thanks for the heads up,that screen does look awesome,as for the decals theyve already clear coated it in the factory.
                          Ill give it a run just to see how it goes and do it carefully LOL.
                          Will keep you posted when i do of how i get on
                          • F1 madness
                            • Feb 2010
                            • 788
                            Well finally managed to get it wet,apart from putting some thread lock an all the nuts,bolts and grub screws just chucked it in the drink to see what happens.
                            Had trouble with cavition,forgot my prop box so couldnt try any bigger props,as iv got some 36mm,3 blade counter rotating props,comes with 34mm,3 blade 1s out of the box,but got speed and motor esc and batts were hardly warm.
                            here you go:
                            2nd run after checking temps:
                            3rd run ended early:
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              Very nice Daz looks to be running pritty good!!! you need a bigger pond with less boats in it and let that baby scream!!!!
                              • Bug777
                                • Jun 2010
                                • 98
                                Nice vids there mate. What size LIPo's are you using.?I found that i picked up a lot of speed when i changed LiPos from LRP 2200mah 3S 25C to Turnigy 5000mah 3S 40 - 50c. in my EKOS. Also around 1 - 2 mm negative pitch on the props got my EKOS going the best in slight chop.
                                FighterCat57, What are wheel collars & where do you get them from?
