rips tsb gen 3 cat
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    At 4200w a piece that thing will have just over 11.26 total HP! What size props you looking at x457?
    • RIPFENCE
      • Sep 2009
      • 1332
      Originally posted by blackcat26 View Post
      at 4200w a piece that thing will have just over 11.26 total hp! What size props you looking at x457?
      i have 2 counter rotating abc props right now that are 58.8 mm 3 blade 1.6 pitch...as you know there are just not that many stock prop choices for left and rh rotation...
      "FE" STANDS FOR FRUSTRATING EXPLOSIONS
      • RIPFENCE
        • Sep 2009
        • 1332
        hahaha i guess i really should have thought a little more about that!!! it probably will not need red bull to give it wings!!! i have never seen vids or anything on this hull so you just do not know whats going to happen...
        • blackcat26
          High Speed Junkie
          • Sep 2009
          • 1598
          I think you will be taxing those drive shafts for sure. May want to go to 1/4" flex with the 3/16 stub on it....
          • RIPFENCE
            • Sep 2009
            • 1332
            the stingers are for 1/4 flex...and yes i have the 3/16th stubs..
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1598
              Sounds like you are ready to put down some power! Let's get this thing cooking!
              • RIPFENCE
                • Sep 2009
                • 1332
                too bad its going to be frozen before the cooking happens..looking forward to the spring thaw..btw i watched you geico vid..real nice job
                • blackcat26
                  High Speed Junkie
                  • Sep 2009
                  • 1598
                  Thanks bro! Potentially I could run year round here just have to get used to numb fingers!
                  • RIPFENCE
                    • Sep 2009
                    • 1332
                    ok finally have an update and got a few things done..first of all i got my motors glassed in and they came out decent..i have been waiting on a couple of drive shims i needed to have cut out of t6061 aliminum..since the transoms of this cat are cut a 85 degrees i needed to have these shims cut so my drives could start out level..my buddy at work milled these out on his milling machine..also got the drives mounted tonight..these stingers look beastly and are perfect for this hull since the length can be adjusted and the positive and neg trim angle is adjusted by the socket head screw on the front face of the drives unlike most stingers..this gives me enough room to get an allen wrench underneath the wheelie bars on the hull..also installed transom doublers for reinforcement and used the system 5 marine grade epoxy and hardener to get them set..system5 is the shiznet!! more updates to come
                    • blackcat26
                      High Speed Junkie
                      • Sep 2009
                      • 1598
                      Oh man those stingers look kewl!
                      • RIPFENCE
                        • Sep 2009
                        • 1332
                        Ok its been a while and i have been slow going on with all my boats i am building...first update is with the props.."chuckegneg" did an outstanding job on the abc three bladers..how he works his magic is beyond me!! I installed the hitec servo and heavy duty rudder linkage using a simple cheap aeromarine servo mount..1/4 flexes were obvoiusly installed..next will be some brass flex tubing supports and installation of swordfish 240's when they come back for repair..until next time
                        rip
