i had a large box show up today...
after 6 weeks i go my top secret boats gen 2 cat..after seeing it in person its well worth the wait. bill from tsb did an outstanding job on the hullthe finish is almost flawless with just a few minor scratches on the underside of the hull which is nothing at all...i was astounded by the actual size of the hull..its big and its heavy...the hull tips the scales at 11.5 lbs
definately designed for a big gasser...but this is not offshore gassers now is it. which brings me to the very first dilemma of the build thread..how do i get this heavy of a hull to 65 plus mph? anything less is going to do this beauty an injustice IMO i already purchased a scorpion hk 4035 from jason in the swap shop but i really cannot see the motor being able to push this thing..the hull is screaming twins so maybe 2 hk 4035's 800 kv on 10s each might be the answer?!?!? i am going to need all the help i can get on this one..also if i do go twins which drives should i use? this hull is equipped with wheelie bars on the transom which overhang 5.25 inches off the transom as shown in the pics...whereabouts should i be thinkning about mounting the drives?? there is a ton of room inside the boat so twins is definately possible...thank you in advance for help good bad or indifferent..oh yeah its a gen2 cat not 3
