Villain Single drive 700sc
  • Quicksilver
    • Jun 2007
    • 211
    Thought I'd make a build thread for this one. I'm just waiting for parts, which I'm sure will be a matter of hour, not days :)
    setup will be as follows,
    villain hull 30"
    700sc motor
    Jeti Navi 600
    SV27 flex drive and strut
    DIY rudder
    16 IB3600's
    CF 2217.42 prop
    some pics of the boat and the rudder I just finished, last pic was taken an hour after starting to file down a rudder out of stock.
    BOATS CAN FLY AND SHOULD!
  • Quicksilver
    • Jun 2007
    • 211
    one more pic........side by side with the jet-villain
    • Quicksilver
      • Jun 2007
      • 211
      much more done today.
      I will say with all the parts I received, the only one giving me trouble is the drive dog grub screw, it's microscopic. I have three hex wrench sets and none had that size. Besides that, I've just been learning as I go.
      • Darin Jordan
        • 8332
        I love seeing these mod projects... we're definately having a good time in this hobby, aren't we!??!!
        If you are into some build advice... One thing that I do to assure a friction-free stuffing tube/flex assembly is I always mount the hardware and motor first. Then, I install the stuffing tube and use the motor and strut to keep it in perfect alignment by installing the flex to hold it all in place while the epoxy dries... Then there isn't a lot of tweaking to get the flex to line up...
        I still love the idea of the jet... I'm going to do that one of these days!
        Darin E. Jordan - Renton, WA
        • Quicksilver
          • Jun 2007
          • 211
          thanks for the tip. The stuffing tube and teflon liner, are not epoxied on yet, just a mock up. I haven't done a flex drive boat before, so I'm being cautious and trying not to rush things. The only reason I've gotten so much done, is because I've had some days off. I've been messing around with motor placement, definitely will do it the way you said, I'd like the possibility of a cable failure to be as low as possible.
          After I've got this boat running, then I'll go back to the jet boat, it's going to be completely gutted of everything not abs and rebuilt. you should do a jet, they're so cheap. Just the few bits of hardware I've spent on this surface drive, is more than a jet unit., only $55 for a jet just like the one I have or diego's.Or should I say the jet boat for known as diego's.
          • steveo
            • 1454
            i have done the same to my old villian , i cut out the inner hull part where the batts were gave alot of extra room to stiffen the hull and battery placement, with a 700 and 12 cells it was a fast boat , i did have to use trim tabs but proper set up could have done with out i did not know much at the time, i do want to see some video with 16 cells
            good work
            • Quicksilver
              • Jun 2007
              • 211
              got an update, motor and flex drive are hooked up.
              • Quicksilver
                • Jun 2007
                • 211
                more updates, besides sanding my fiber glass work on the exterior and figuring out the battery positions, she ready to get wet, even though it's snowing
                • Quicksilver
                  • Jun 2007
                  • 211
                  I left this thread dead...opps! boat is just being dialed in now. did not run well at first, but now is getting more controllable.
                  first run
                  second run
                  • kal1b3r
                    • Oct 2007
                    • 38
                    looked very unstable on the first run
                    RC boat Noob lol
                    http://www.mafiacrime.org/r.php?id=9137
                    • Quicksilver
                      • Jun 2007
                      • 211
                      I agree, hence the second run.
                      • Steven Vaccaro
                        Administrator
                        • 8724
                        The second run was better. What did you change? Strut angle?
                        Steven Vaccaro
                        • Doozie870
                          • 828
                          Seems like the batts are kinda high up there, is there anyway to cut what they are sitting on to drop them lower in the hull. Nice boat btw.
                          • Quicksilver
                            • Jun 2007
                            • 211
                            yeah Steven, I changed the angle. It's tough on that transom, it's still not quite neutral, which is why I think it's still bouncing. It was about negative 5 degrees, now it's about negative 1 degree. I also moved the batteries forward; in the first video theyre along side the motor. btw thanks for that prop choice, the motor's running cold, along with the esc. Batteries below 100 degrees, just warm. You have a recommendation for the next step up?
                            Doozie; I agree, I like keeping most on the inner hull, but it's apparent it'll have to go in order to lower the COG. I think it would end up with all 16 cells on the centerline, dropped about an entire inch. Think I'll have to stiffen the hull there, since all that weight could compromise my motor mount in an abs boat.
                            Keep the advice coming, I appreciate anything
                            It's nice to know I have some more room for improvements.
                            • Quicksilver
                              • Jun 2007
                              • 211
                              actually this wasnt too bad, get to keep some of the inner hull for strength and makes a little tub for the packs. :)
