OSE Brothers Outlaw
    • 9479
    #46
    Originally posted by CHUD View Post
    Hay brushless how's the flex shaft going to take being that short,and are ya going to move up to A 187 flex or is the standerd 150 going to be O,K
    Good question?
    I will move to a 187 if needed...
    now what's a good way to take out most of the rails in this boat?
    I got my CG laid out...
    • CHUD
      • 497
      #47
      brushless my brother hydrojerry has a tool called a drimmale that you can pick up at wallmart it has some vary good disk's that will take the wood down ,thats the only thing I can think of,Hope it helps
      • ozzie-crawl
        • Sep 2008
        • 2865
        #48
        Yea i have cut rails out before with a dremel and carbide disc before. some have a little router type bit that will grind away the bit thats left after drilling.
        • Visual Perfection
          • May 2010
          • 312
          #49
          I run mine about 30% for the COG and it works great...and that is the point at which it runs most stable for me. Just thought I'd share.
          The Speeders *PB SW 26 BL *PB Formula FASTech
          The Cruiser *CBM Marlin Cruiser
          The Pool Toys *Proboat Mini-C (x2)
            • 9479
            #50
            I think I have two of those..
            I'll look for that disc..
            I have my electronics set back to 27% for loose and have my packs able to move forward to 30%+ if I want
            thanks
              • 9479
              #51
              Ok, I pulled the shaft to order a collet, and it's an od ball size of 0.171
              so I am placing an order for a few things including a 0.187 shaft for this one
                • 7651
                #52
                That must be 4mm?
                  • 9479
                  #53
                  That must be 4mm?
                  about 4.35mm
                  and I just placed an order for a 0.187 cable and then a motor for my P-Mono
                  • CHUD
                    • 497
                    #54
                    how did the woodworking bizz work out brushless ,lets see some pic;s bud
                      • 9479
                      #55
                      well....
                      I spent all weekend through Monday, with my girlfriend for her birthday, so I have not gotten much at all done
                      and I've put off building a second P-Spec racer this week to..
                      I'm am trying to do a quick mod on a SV27 and see how that goes for this weeks races.
                      • kilr95ss
                        • May 2012
                        • 38
                        #56
                        Watching this thread closely, just bought a Outlaw myself and it is way too slow! Have a Vegas Deuce and had a Toxic Marine modded gas cat. Must go faster!
                        Charles Spradley
                        If all else fails, GAS IT! This will either fix the problem or end the suspense
                          • 9479
                          #57
                          So I am changing my ideas on power for this one..
                          may sell off the CC1717 with mount and find a motor to run 8s
                          who has some ideas for power?
                          I'm looking for solid mid 60's, or even 70 if I can
                          • Miguel187
                            • 5
                            #58
                            Hi Brushless55,
                            I've also been following this thread as I want to convert my outlaw into something faster too. You could go for the setup as marcelaw posted on here:
                            http://forums.offshoreelectrics.com/...-FE-Conversion
                            The Neu 15271y he uses can handle 8s. But if you want something a bit more affordable (like what I'm looking for :)) perhaps a Leopard 4092 could be an option?
                            grtz Miguel
                              • 5554
                              #59
                              Leopard 4092 1300 kv on 8s is just a tad high for rpms possibly, can you run 7s..........that would get you over 60.
                              http://www.offshoreelectrics.com/pro...o-4092&cat=148
                              • Miguel187
                                • 5
                                #60
                                Yes, but perhaps the 1050 can do it?
                                I read from your boat list you have experience with the 4082's. Are they good motors? Have you ever tried any on 6s before?
