Thundercat31 twin
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1750
    Jeff are you saying to bring the stuffing tubes down thru the tunnel or out the transom behind the sponsons? My factory strut would be basically butted against the transom unless I made a extended mount for them.
    • blackcat26
      High Speed Junkie
      • Sep 2009
      • 1750
      Got a little work done this weekend. Holes plugged and transom filled and primed and got some under hull water pickups installed. Nothing that exciting yet.
      • Jeff Wohlt
        • 2740
        Out each sponson
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • blackcat26
          High Speed Junkie
          • Sep 2009
          • 1750
          Thanks Jeff. I am still undecided.
          • Jeff Wohlt
            • 2740
            With that hull you can do stingers and they are cheap. You do not need long ones. There are a bunch at HOR racing or other places. That hull has great room for a twin set up.
            www.rcraceboat.com
            • blackcat26
              High Speed Junkie
              • Sep 2009
              • 1750
              I think I will stinger it Jeff. Maybe the ones Kintec Racing. Would the bearing ones yeild higher speeds?
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1750
                Slapped some primer down and installed the servo mount tonight. Pretty boring stuff hang in there.....
                • timjz
                  • 344
                  Where did yo get the servo mounts from? They look pretty nice!
                  • blackcat26
                    High Speed Junkie
                    • Sep 2009
                    • 1750
                    It's the one they sell on here. Very good quality and pretty sturdy once tacked down.
                    • blackcat26
                      High Speed Junkie
                      • Sep 2009
                      • 1750
                      Got my motors in. Going with the Scorpion 3026-1600kv for sure. Waiting on stingers for Kintec and got the bottom painted. Used ace hardware appliance epoxy. Went on great and looks good. Well It would look better if I would have sanded the primer a little better.
                      • forescott
                        Hopelessly Addicted to RC
                        • 3009
                        Is that just a gloss white? I got a can of appliance epoxy for the inside of the hull, but if you think the finish looks nice I'd like to try it on the outside as well.
                        • blackcat26
                          High Speed Junkie
                          • Sep 2009
                          • 1750
                          It is a hard finish also. Dries fast and looks good. Yeah its gloss white.
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1750
                            Got one stinger in. The other one is backordered......Figures
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1750
                              Hull and hardware is up for sale in the swap shop!
