Genesis bare hull scratch build.
  • Rumdog
    • 6667
    Recieved my hull the other day. The quality far exceeds my expectations. It is an epoxy glass hull. Sharp edges. No weak spots. No waves. Sanded, and ready for paint out of the box! Also got a pair of stingers. They are a bit short. I was going to machine some extensions. Instead, I stayed a little late at work today and made these bad boys. 5.5" long. Drilled for 7/32" brass to accomodate .187" stub and flex. Mounted to the sponson transoms, they will clear the tunnel overhang by about 5/8". They are an exact pair. Still have to make the mounts for the stingers, but that's the easy part. This should be fun! I plan to fab nearly all the hardware and mounts myself for this bad boy. Will be running twin 9xl's seaking 180's, and 5s1p per side.
  • chummer
    • 650
    I will be following this one!
    I am really surprised by this, I would not have never expected that quality from this hull.
    "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
    • Rumdog
      • 6667
      It was not expected here that's for sure. It is Very well made! Even the join in the hull is sanded smooth as a baby's butt.
      • Rumdog
        • 6667
        Buy one from Fightercat while you can! You won't regret it!
        • Rumdog
          • 6667
          More shots:
          • chummer
            • 650
            I have been considering that. Really love the looks of that hull. Just not sure if I want to take on another electric boat right now. Love F/E but I am just trying to recover from a couple of bad days at the lake. Gets costly sometimes.
            • HYDROJERRY
              • Jan 2010
              • 2709
              Did you get it from him,,man i love these!!!Nice and sleak
              • Rumdog
                • 6667
                Yes. Got the hull fromFightercat. It was the sample hull that they sent him.
                • HYDROJERRY
                  • Jan 2010
                  • 2709
                  lucky..
                  • scullyeng
                    • 54
                    Any updates on this build.
                    • Rumdog
                      • 6667
                      Not yet. I have some serious decisions to make. This cat is a pain in the ass. Single drive would be much easier. It just wasn't built for twins.
                      • Brushlessracev
                        • Oct 2010
                        • 154
                        nice hull, my next will me a cat.
                        • Alfa Spirit
                          • 2183
                          The Genesis hull is a very nice and strong boat, I can compare quality with MHZ Mystic hull, very similar.
                          IMHO this hull is perfect for a twin setup 2x4S, 2x5S or 2x6S. It' s not necessary to buy hi-end components, a pair of Seaking 120A or 180A, two 540XL motors will work very well. The only problem is to find 10cm/12cm powertrims but TFL Hobby is making those parts they will be available soon.
                          • Rumdog
                            • 6667
                            There are a few problems making it twin though. The sponson transoms, they are FAR from square. I have the stingers you show above. They are way too short. Even if they weren't, once mounted, with them trimmed all the way up, the angle is still very negative. The sponson transoms are kicked back way too far. (not 90 degrees to the tunnel) The stinger that i made aren't going to work either. I machined some mounts, but there just isn't enough room to mount them properly. I have a couple things in mind.
                            • Alfa Spirit
                              • 2183
                              This is not a problem, powertrims are adjustable. Mudl' s Genesis with HPR powertrims. Stability and the sound of twins, Waoooww !!!
