I am just getting my boat back together and went with an Etti coupler. %mm to .150 and I have to really push the cable in hard. That normal with the Etti. Before I had octura and the cable just slid right in. ????
Are Etti Couplers generally a tight fit for the cable?
Tags: None
Cable is not a high tolerance item. It can be anywhere from .145-.150. Then if you solder it, its going to be a bit thicker. I think you are better off a bit of a tight fit. Use some sandpaper wrapped around the end to take it down a bit.Steven Vaccaro
As long as it goes in without damaging the cable it is fine and will be nice and tight. Did you solder the cable end? If so then sand it a bit.
Ok, sounds good. This octura cable I had soldered, but sanded it quite a bit and its still tight. I am going to use a prather cable, but was just using the old octura for setup of the new motor position. When I cut the prather cable I'll try the sand paper idea. Thanks! I forget now, I wana "tin" the cable before cutting it with the dremel right? Neu install is almost complete....
