anyone know what the wiring is on the Feigao 11L motor A,B,C red,green,yellow
Newbie new build delta force 26"
This topic is closed.
Twins in a mono is a waste. When the boat leans over in the turns one prop is usually out of the water causing weird handling problems. This boat is also way to small for twins. Keep it simple and you will have more fun and less headache.
Mark
I did not say anything about polarity. just wanted to know how every one is wiring there motors for example yellw=A and so on.Originally posted by Rumdog View PostWhat do you mean? Polarity? It doesn't matter. If you hook it up, and the rotation is reversed, simply swap a pair of wires.
I am not going twins,Originally posted by MarkF View PostTwins in a mono is a waste. When the boat leans over in the turns one prop is usually out of the water causing weird handling problems. This boat is also way to small for twins. Keep it simple and you will have more fun and less headache.
Mark
half agree, boat too small yes. Twins a waste? don't agree. Beautiful sound, motors run cooler, you have a back up if one dies, no torque roll, I could go on. But yes for this hull the weight would be an issue if you did actually get all to fit in there. It sounds like you have abandoned the twins idea - maybe another hull? twins rock!Originally posted by MarkF View PostTwins in a mono is a waste. When the boat leans over in the turns one prop is usually out of the water causing weird handling problems. This boat is also way to small for twins. Keep it simple and you will have more fun and less headache.
Mark
How's progress?"Look good doin' it"
See the fleet
Jeese, In my 15 + years of boating I have only heard of 2 or 3 monos being converted to twins. In most of those instances they thought the boat would handle better than it did. Having the right mono and the props in the right place are very key to the success.
By the way I'm well aware of the benifits of twins but your comment, you have a spare motor if one dies. Really?
Mark
Its AC. Hook it up if it runs wrong direction flip two wires and bam... right direction!42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)
Originally posted by Brushlessracev View Postspeed control is marked for a reason, A,B,C terminals,
Ignore A,B,C etc..............just solder connectors and hook em up............swap any two wires to reverse if wrong.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
just go with it brushlessv
ignore all negitive comments, just a waste of time. all questions are welcome here. when i started on OSE i am sure i asked a few (understatement) of nonsence questions. all answered. as your post says "newbie" that qualifies you to ask anything you want.... if people respond with such things as "It only took four different guys telling you before you believed it" just ignore it.. i am sure he asked some stupid questions when he was new also... keep us posted on teh build and if you have any questions ask them. i have owned 4-5 DF 26" so if you want PM me...see my fleet
: http://forums.offshoreelectrics.com/...hp?albumid=294
