Here goes again. heading into the cold Michigan Fall/Winter so I am heading down to the basement to start a new build. I have a new child coming in the next couple weeks so this will be a slow yet very detailed build. I received the hull a couple months ago and just started this evening on mounting the struts. I have all parts except motors at this point. Each post I will show pics of progress.
H&M Maritimo
Tags: None
I have mounted the 2 sv struts that have been modified with lead bushings. They seem very smooth and couldnt beat the price. I used the masking tape to mark holes and they came out just as i wanted. Next to come is the rudder system.Attached Files
Getting a chunk of spare time today I modified dual rudder system, instead of bending to shape i cut just what i needed and still need a little machining to do on them but they work perfect. I am also going to trim about 3/4-1" off rudders. Holes are in boat and as you can see with crearance. Im only mounting them once after paint.
I have always wondered why RC rudders are squared off at the back ends. Would it not help if they had a sharp exit as well as entry into the water?
I've wanted to try with two of the same rudders, and making one with sharp exit,Originally posted by AtlanticChallenger View PostI have always wondered why RC rudders are squared off at the back ends. Would it not help if they had a sharp exit as well as entry into the water?
to see which one has the most drag. I think the wedge allows the water to come straight off the end of the rudder, while a sharp edge may pull the water from both ends together causing a vacumm efect.
I Dont Know what Im saying. lol
Island Boys Fast Electric Hawaii
It wasnt alot of trouble to go with dual's at this point. I am looking for handling all the way. If need be I can mount just one in central location and well, it looks cool as hell in my own opinion.
After looking at some diff. pics. I thought it had twin steerable I/O type. Just thought rudder was more of a turn fin (stationary). Looks like I have 4 output cooling holes. 2for esc's 2 for motors.Originally posted by G Doggett View PostMight be a silly question, but why are you going to the trouble of twin rudders ?
The real boat has one mounted central on the provided rear extension where it is clear of any prop wash.
Graham.
Or something like that. still looked cool
On a twin cat you want the stingers as close to the tunnel and as far down as possible. They will cavatate like crazy if you dont get them down. ( especially at high speed.
good point but if you look at the inside hull pics its as close as possible using back plates. I know speedmaster stingers would have been larger since i used them before and with the weight of twin motors . well we'll see.
The hull was indeed rough and needs finished but its fun to do. I put all the holes in first for hardware since I dont have patience once its painted. will post pics of that soon.
