Twin Toysport Triton
  • Jesse J
    scale FE enthusiast
    • 7818
    Got a deal on some hardware... transom was all for it...
    here is the hull for starters
    Epoxied in a ply transom - it is all fiberglass and gel - no ply at all.
    More updates soon - got the boom mounted and two stingers. Gonna run a couple Feigao 9L motors for now on 2-3 S to get started.
    "Look good doin' it"
    See the fleet
  • Jesse J
    scale FE enthusiast
    • 7818
    here is the mock up. holes are drilled, minimal bolts tight, nothing inside hull yet. Still manufacturing twin motor mount. Thinking aluminum bolting to 4" rails.
    See the fleet
    • JMSCARD
      • Mar 2010
      • 4174
      Very Nice Jesse!! I like how everything is nice and tight yet everything still has the clearance it needs... if I put something like this together it would be all %@*! up...lol...
      • Jesse J
        scale FE enthusiast
        • 7818
        Thanks Jason! yep, pretty happy how the rudder boom ended up working out, I was worried the props would have to be too far apart, but I think this is a reasonable spread.
        and Yes, the struts can come down to the base of the transom, so yes adjustability is KEY for this guy. I got a replacement rudder comin from Fuller, should be a perfect fit... now for laying some stringers and then the flex tubing....
        See the fleet
        • Chuck E Cheese
          • 2136
          i have been wondering why nobody puts twins in a mono... i know our real mono runs twin surface drives. nice job
          see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
          • Jesse J
            scale FE enthusiast
            • 7818
            Probably main reason is its more than twice the work - and you are battling with keeping everything as close together as possible, and then that rudder!! where the hell does it go? also twin motor mounts are not just kicking around like buttered popcorn on the floor at the dollar movies.
            Peter Zicha is gonna work me some CNC love on this motor mount... I am probably gonna line her up with some CF - just cause it will be that much cooler. It couldn't hurt adding stiffness given that it will have its little belly full of electronics!
            See the fleet
            • Steven Vaccaro
              Administrator
              • 8934
              This should be interesting!
              Steven Vaccaro
              • Make-a-Wake
                FE Rules!
                • 6057
                Neat build Jesse..................you really got the props snugged together!
                • blackcat26
                  High Speed Junkie
                  • Sep 2009
                  • 1750
                  Hurry up and get some motors in that thing!
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    I'm checkin the snailbox everyday.... maybe I'm lookin for too small of a box.
                    Thanks guys, yes props snugged together, but want to avoid the common complaint uttered by the first post after somebody says,"can I put twins on my deep vee hull?" I figure with a low angle vee and props almost touching, she ought to steer alright.
                    I got some CF comin and my 1/8" ply for the stringers. Just mounted up turn fins and waitin on some OFE trim tabs and props.
                    I hope my main man Egneg is up for some sharpening...
                    See the fleet
                    • Jesse J
                      scale FE enthusiast
                      • 7818
                      Isn't that better? I was thoroughly unchallenged when setting up the now Jason's DF 29 and unsurprised at how beautifully it handled on her maiden voyage.
                      I am realizing I enjoy the engineering and design of the build as much as actually putting it together. You know, stewing on how to solve a little pesky step and then while walking the dog or washing the dishes it comes to you and you almost have to stop what you are doing at that moment and go back to the shop to see if it works the way you thought. that's how the rudder solved itself!
                      See the fleet
                      • Jesse J
                        scale FE enthusiast
                        • 7818
                        updates
                        Carbon fiber mat
                        4" custom 1/8" rails (for custom Zicha motor mount)
                        long Fullers boom with rudder
                        twin stingers, trim tabs and turn fins
                        twin through hull water intake
                        See the fleet
                        • JMSCARD
                          • Mar 2010
                          • 4174
                          Holy smokes jesse you put together some builds in a hurry!!! I see the big kitty already in the water... now this... geesh... whats your woman say to your time management...? lol...
                          Very nice work though... cant wait to see this one go!!!
                          • RIPFENCE
                            • Sep 2009
                            • 1577
                            Carbon fiber mat
                            man thats friggin awesome...its going to smoke for sure
                            "FE" STANDS FOR FRUSTRATING EXPLOSIONS
                            • Jesse J
                              scale FE enthusiast
                              • 7818
                              thanks both for kind words.
                              AAANNNNNNDDDDD I am finishing my dissertation. (little breaks add up to progress, eh?) Oh, yeah and the ponds will be solid in 2 months... so now or next year.
                              Woman is pulling my hair dragging me out for a dog walking at the moment.
                              Motors are here, but cooling jackets are loose, so a pair of shiny Kintec Racing ones are on the way (need the nipples to be aligned not offset...).
                              now waiting on motor mount - in the mail - and my pair of X442 props from the Egineger
                              See the fleet
