Copy Cat
  • Chuck E Cheese
    • 2136
    Copy Cat
    this is my hotr cat, i copied the build from fightercat 57. i am using the turnigy 600 1400kv heli motor, turnigy 180 esc, 3s 5000mah 40c x 2 in series for 6s, hitec hs225mg steerign servo, hotr hardware and starting with m445, m545, m447 props. i was going to use a wire drive but couldnt get a 6mm to .072 coupler so i went with .187 which is what i have. getting ready for the maiden voyage today, will post results later tonight. if all is dry on the first run i will throw in the eagle tree and get some data on the set-up..
  • Rumdog
    • 6667
    Sweet! You do charters?
    • Jeff Wohlt
      • 2740
      Do you mean 6mm x 078 coupler? They may not be on my site but have been making them for the bigger outrunners.
      Jessie has a 6mm x 1/4 coming for his new big cat.. Whatever the size...do not hesitate to ask. They come many combos.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Chuck E Cheese
        • 2136
        jeff you said you would make one for me in a couple weeks. i tried sending you a pm 2 weeks later and never heard back...
        rum - thats what i do, run fishing charters... check out the site and if you are ever in hawaii look me up.
        • Chuck E Cheese
          • 2136
          well here are the results. first run m445, 52mph, 121 amps and motor around 130 degrees. 2nd run was m447, 55mph, 154 peak amps and same temps. all data taken from eagle tree. i didnt have any temp sensors or rpm sensor hooked up but i will soon. i will try and post the files next time (it is all on my laptop now) as well as get some video.
          in the end i ended up running a 215 prop. i dont have any data on it but it was alot better for playing around. my guess would be mid to high 40's on the 215.
          this motor seems to be a power hog. i wasnt that happy about the peak amperage being so high. it wasnt constant but it did peak at several times over 135 and was over 100 whenever on the gas.
          the boat ran good and straight with a nice ride angle and no porposing. it was a straight line monster but doesnt turn for beans... it is a slider. i run in a small pond and it was alot of off the gas to make the turns. i am sure it has more speed with the same props as i could never let it run, the tide was low and the land came up quick.
          overall i can say this is a pretty good boat. i hit the set-up pretty good as i didnt adjust on anything yet. it reminds me of a tunnel as it slides the turns.
          • Chuck E Cheese
            • 2136
            oh i did a little set-up on this boat and have eagle tree files if anyone is interested in the big outrunner. i was running a stock s/b m445. i added 1lb of weight to the right sponson to counteract the torque of the motor and it settled it down quite a bit. i was pretty happy with how it ran today. here are the numbers: rpms are higher than i like, max amps 162, speed 52. once again, notice how the cheap turnigy batteries have no significant drop in voltage as others claim.... 2 x 3s 5000mah 40c in series.
            here is a vidio,
            • Jeff Wohlt
              • 2740
              Sorry, maybe it went to spam. If oyu need anything just PM me here.
              www.rcraceboat.com
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                Chuck-E,
                Could you try a 937/3 prop?
                It's calculates to pull the same as an m545. Maybe more pitch with less blade will keep it under control.
                • Chuck E Cheese
                  • 2136
                  i dont have one but sounds like a reasonable set-up..
                  • Chuck E Cheese
                    • 2136
                    pictures of my other cat... i just couldnt resist
                    • OshkoshMono
                      • Apr 2010
                      • 207
                      You run fishing charters in Hawaii !!?? You are my new hero. I so want out of the frigid cold north. I have all these tropical reptile pets in the basement that use huge amounts of electricity to keep warm all the way up here in WI.
                      Anyway...Sweet new cat! I keep trying to click on "see my fleet" but it doesn't work. Hawaii...I'm gealous! Mahalo!
                      • Chuck E Cheese
                        • 2136
                        i am always looking for deck hands..
                        i cant figure out how to change my signature, that is old anyway. here are a few of my current boats. also have jae 12fe, jae 21fe.
                        building the rico and another jae..
                        http://forums.offshoreelectrics.com/...ad.php?t=14877
                        http://forums.offshoreelectrics.com/...ad.php?t=13059
                        http://forums.offshoreelectrics.com/...ad.php?t=15660
                        http://forums.offshoreelectrics.com/...ad.php?t=15188
                        • Ub Hauled
                          • Aug 2007
                          • 3051
                          Originally posted by FighterCat57 View Post
                          Chuck-E,
                          the 937/3 is not a sport prop by any means... just make sure that it won't burn your stuff up... high pitch props always tax the ESC and batteries a lot more then lower pitch bigger blades...
                          • Chuck E Cheese
                            • 2136
                            ya i am getting plenty for a sport "fun in my small pond" with a 215, i am not even going to try a 937..
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Yeah, I'm going to learn more about them and start lower rpm and guesstimate it about like a 447 setup wise and go from there.
