Project Sprintcat! FighterCat Goes Ligit!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    The only thing I really need help on is properly calculating the battery requirement.
    I don't think that 6s1p 45c 5k will be enough but could be wrong.
    • Rumdog
      • 6453
      I'm willing to bet that it will be plenty. Amp draw should stay relatively low since it is a twin.
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3480
        Just in case though, I'm going to add four caps to prevent any possible voltage drop.
        • Jacked1
          • Jun 2010
          • 772
          You could get 2 sets of 3.3Ah 45c batts and get a little under 150 amps per side? It would be lighter that 2 sets of 5000Ah. Or something like that.
          Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
          • bustitup
            • 3071
            #35
            Originally posted by FighterCat57 View Post
            Yeah, it's the 36" hull
            its really only measures 34.5
            tip to transom
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              #36
              tip to transom
              Ya know. I never measured it, just recalled how it was referred to in hearsay. 34.5 is correct though. Explains why it fit on my 36" bookcase shelves.
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                #37
                The turbo fans are here!
                4CFM focused right on the ESC's. They are ultra light brushless fans!
                The 40mm square fans are for the motors and will be mounted in the sponsons hanging just above them.
                I have an Rx controlled solid state switch that I'll use to switch them on and off.
                I've been seriously considering using a small EDF. He he.
                • Rumdog
                  • 6453
                  #38
                  Cool!
                    • 9479
                    #39
                    40CFM focused right on the ESC's. They are ultra light brushless fans!
                    cool looking blowers!
                    where did you find those?
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #40
                      There's probably better deals, but these guys had a bunch of other stuff I wanted too. http://www.coolerguys.com/
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        #41
                        I decided to keep with the nice gelcoat finish and apply some decals. This way, I can easily change my mind later. =)
                        What do you think, flames or no flames?
                        • Heath M
                          • Mar 2008
                          • 806
                          #42
                          gr8 looking hull.
                          Can i ask why you mounted the struts close to the inside edge of the sponsons and not the middle?
                          Brisbane,QLD, Aussie
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            #43
                            Originally posted by Heath M View Post
                            gr8 looking hull.
                            I have no science behind it, just following what I saw on another build. Are they supposed to be in the middle?
                            • Heath M
                              • Mar 2008
                              • 806
                              #44
                              No, not that i know of. I was just wondering if there was a technical reason for mounting them there.
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3480
                                #45
                                Nope. Just thought it looked right there. Hmmm. Center mounting would keep the drive wires straighter.
                                Wonder if it's worth re-drilling them to move a bit.
