Swordfish 240 settings, props and motor temps
  • OshkoshMono
    • Apr 2010
    • 207
    Just wondering if the PWM setting for the swordfish will effect motor temps. My fiago 540xl 12 is around 180+ degrees after a short run at mostly 1/2 to 3/4 throttle. I have the pwm set to 15khz. Should it be at 8 or 12khz instead? the prop is a 45mm 2 blade graupner, so i ordered some more graupners in 40 and 42mm. unless the pwm setting has anything to do with it, the props should drop temps right???? Thanks for any advise you can give!
  • OshkoshMono
    • Apr 2010
    • 207
    I think I found the answer to the PWM setting question. It seems the higher PWM, yo will gain a bit in performance, but run the motor hotter and shorten run time. (also explains my poor runtime) So....maybe I did'nt need to order the smaller prop? I just set the esc pwm back down to 8khz, so hopefully the temps and runtime improve.
