Project Apparition TWO!
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1591
    Where did you purchase the motor mount? The ones on OSE will not accept the 4mm mounting screws.
    Thanks in advance,
    Ray
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Thanks in advance,
      Ray
      Indeed. They are from OSE and now accept 4mm screws thanks to my drill.
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        Still waiting on ESC cooling blocks and GPS to get here... *chomp* *chomp*!
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          OK, GPS and Cooling Blocks are here and installed! Thanks to Boatman and Bustitup!
          Decided to just go for it and put an m545 prop on it. 6s, 1400Kv = ~31K RPM so I'm pretty sure it's safe.
          Anyone want to FE calc it?
            Should be o.k. but, bring it in and check esc temp after 1 min max.
            I detonated one of those esc's with that motor in my 29" Phantom Cat. Don't get it wet !!!
            I decided to use 5S2P after that first run on 6S1P, I was using a funky Y547 cut down to 44mm but it had too much blade area. Motor came back cool.
            50.5mph on GPS, and they were 4yr old Poly rc 25C 5000's.... M545 will be a bit better on speed and less amps somwhat.
            Try an M445 first.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              Try an M445 first.
              Ah, yeah. They don't come with any conformal coating. I sprayed this one up pretty good... so fingers crossed.
              I have an m445, so sure, I could try it first.
              • Jacked1
                • Jun 2010
                • 787
                Hope it all goes great!
                Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  Bench Test: http://www.youtube.com/watch?v=IB33nGf9_Og
                  Just playing with the throttle a bit. Watch the hull twist.
                  • Jeff Wohlt
                    • 2740
                    Nice...smooth drive! :)
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      Yeah, those wires are precision! Nothing out of balance there!
                      • Graeme
                        • Jun 2010
                        • 97
                        Looks like a heart beat the way the hull flexes
                        what do you use for a gps ?
                        • F1 madness
                          • Feb 2010
                          • 788
                          Sweet,cant wait to see it hit the water and see how goes if your feed back is good i will be ordering 2 x of these for my twin outboard cat on 6s or 7s each
                          http://s577.photobucket.com/albums/s...79/F1%20boats/
                          Daz from sunny England
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            Heh, yeah, never thought of that. That's funny!
                            I'm using a good ole Forerunner 101, tucked into the sponson.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              45mph... I guess it helps if you charge your lipos.
                              Nice and dry inside, very smooth runner, turns well... for the minute it was running.
                              • Jacked1
                                • Jun 2010
                                • 787
                                That is a fast first run!!!
                                That is with the m445 right? Sounds really good for discharged batts!
