I decided to build my first twin cat. The MM hull is on the way and I plan on 6s and going with two 200amp cheepo escs. I am going to use two of one of these two motors...
http://www.hobbyking.com/hobbyking/s..._Heli_(1100kv)
..or..
http://www.hobbyking.com/hobbyking/s...kv_(600_class)
Does anyone know if the typhoon will be able to pull about 90 amps without overheating? I have one but i don't have an eagle tree or amp meter to test it. I really wanna see what happens with the bigger ones because they are more power but they will be harder to install. I don't know if i will even be able to keep it in the water with that much power either.
There is a boat club kinda close to me that uses mostly gas and nitro so i want to scare them a little bit!
Thanks for any suggestions!!
..or..
