New DF35 with NEU power...
  • gerardobrandao
    • Mar 2008
    • 166
    Hello guys....
    Just to show you mine new summer project..should be ready next weekend....let´s see what this puppy can do with a X648 a NEU 1527 1.5D and 8800mah 45 C enerland cells.....
    Hold on tou your hat....expecting 60-65 mph...
  • andym
    More Go Than Show Prop Co
    • 2454
    Looks good, plenty of torque and power there !!!!
    • Himalaya
      • Apr 2009
      • 259
      Nice build. My buddy is working on a similar setup.
      • gerardobrandao
        • Mar 2008
        • 166
        Hardware Mounting
        Hello
        Just to show the progress of the work:
        [IMG]http:/
        Hope you like it
        • Rumdog
          • 6667
          Very nice! She will FLY!! I ran a 1.5d on 5s2p in a Aeromarine Sprintcat (34"), and with a x455 it ran mid sixties. Watch it though, these motors can be quite the amp hogs!
          • Alfa Spirit
            • 2183
            Very very nice, but I don' t like the color
            • gerardobrandao
              • Mar 2008
              • 166
              DF 35 NEU video
              Hello
              Just to show you today test...running a little bit on the loose side for mine taste, but i have a lot to take from there...Running 6S2P 4400 enerland 45C cells with NEU 1527 1.5D with a M645 only S&B....Hope you like it...
              That motor is a beast.....no questions asked..
              • tth
                • Apr 2008
                • 1600
                Looks nice.....She's fast thats for sure. If you have one, try a M447. I have had great results with this prop on 33-36 inch mono's.
                BTW......Love the color my next Cyberstorm will be like this.
                • Jedi Master
                  • 242
                  Awesome!!
                  Do or do not, there is no try!!!!!
                  Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
                  • RaceMechaniX
                    • 3024
                    Very nice Gerado, she is quick.
                    Tyler Garrard
                    NAMBA 639/IMPBA 20525
                    T-Hydro @ 142.94mph former WR
                      • 9481
                      Lots of power!
                      • gerardobrandao
                        • Mar 2008
                        • 166
                        Df 35 neu
                        Thanks for the input guys.....
                        Mine eagle tree is showing 180 amp peak draws....These motors are Amp Hogs...for sure, but power has to come from anywhere
                        I started with a "small" prop, but for going faster i will go for higher pitch props, and not higher diameter.This is a rigger motor, and not a mono motor...I would have been better served with a NEU1521 1Y wich has higher KV 1577 against 1500,and a lot more torque wich allowed me more room for props...But i´m getting huge smiles with this setup
                        COG 33%, trim tabs even with the bottom of the hull...
                        Tyler
                        Shulze speed controller 32-200WK with the NEU is working trouble free...No cutting off sustained amp draws of 180 AMP, and no problem!
                        Still the problem of cutting off with the HK4035 800Kv, and not running the leopard!
                        Still haven´t opportunity to test the LB5692 2Y in any boat!
                        It will be a good motor, for sure....
                        Very Best Regards
                        • tth
                          • Apr 2008
                          • 1600
                          I did forget to say that my M447 is pitched up with lots of cup and also back cut....(thanks AndyM) aka propmaster!!! I'll show some pics later. He does wonderful work.
                          • RaceMechaniX
                            • 3024
                            Gerado,
                            Good to hear the Schulze is working good. I ran my Conquest on 8S and 10S all weekend with a 32.200 and worked perfectly. Even shutting down when it exceeded its internal temp limit. Much nicer having a boat shut down safely then blowing up fets! I was very close to if not over 200A for some of the 2-lap runs.
                            Tyler
                            Tyler Garrard
                            • m4a1usr
                              Fast Electric Addict
                              • 2036
                              Where the heck is your stuffing tube? I see from the first picture there is no flex support? Are you running the hull with 3 or 4 inches of bare flex?Or are the pictures from early in the build?
                              John
                              Change is the one Constant
