32" cat build
  • amo123
    • Jul 2009
    • 63
    32" cat build
    okay so got the 120 swordfish and was gonna run an 8xl....but with the amount of feedback from you guys i am not feeling like trashing stuff....so with the swordfish and two 3s2p 5000mah batts....what motor should i get ? finances have loosened up a bit and i am able to get something now.....what do you guys recommend for motor and prop to get this thing to sing? or should i just use 4s2p....and with what prop? thanks again guys....
    ao
    savage 4.6 - blackjack 26 - e-revo - HOTR 32" Apparition - blade cp - blade sr - trex 450 -
  • forescott
    Hopelessly Addicted to RC
    • 3009
    I've been waiting for someone to give this motor a try on 6s....http://www.offshoreelectrics.com/pro...od=dh-gpmg5325
    • amo123
      • Jul 2009
      • 63
      Anybody with this "same" boat got any input? Don't mind buying extra stuff, just want to see this thing do something other than sit on table!
      Ao
      • ozzie-crawl
        • Sep 2008
        • 2943
        a 8xl on 4s with a x640 should put you around 50 mph,but i would keep run time short
        not sure if the 120a esc will be enough
        • JMSCARD
          • Mar 2010
          • 4174
          I like my NEU 1515 1.5y's (1500kv) they keep the amp draw down with the lower kv then the 1y and I run 5s and 6s on mine depending on what I am looking for speed wise.... they run cool and fast too! I have 3 of them!
          • amo123
            • Jul 2009
            • 63
            so gots an x642 prop already....what are the main differences in x640 vs. x642? how does the pitch scale go? high numbers or low numbers = more/less pitch in prop.
            • ozzie-crawl
              • Sep 2008
              • 2943
              from memory with a 8xl you will pull about 20 more amps with a x642 over a x640 but gain very little if any more speed on a 4s setup
              on 3s you may pull around 10 amps more and again speed would not change much.
              this is with the HOTR cat hull, but it was my first back into fe boat so maybe a better setup would see more speed
              • forescott
                • 3009
                First number is pitch... 6=1.6pitch...4=1.4pitch And last 2-numbers are prop diameter....40, 42 etc.
                • forescott
                  • 3009
                  x642= 1.6 pitch, 42mm diameter
                  • 785boats
                    Wet Track Racing
                    • 3423
                    In my old Apparition I've had an 8Xl on 4s with an X440/3 blade prop doing low 50's
                    It's now got a 7Xl in it spinning a 437/3 blade prop doing about the same speeds but using more amps to do it. So I might change it back.
                    If I was going to set it up for 6s I'd be tempted to try the 1400kv version of the Leopard motor.
                    http://www.offshoreelectrics.com/pro...ushless+Motors
                    Your 120A swordfish may hold it if not over propped.
                    Cheers.
                    Paul.
                    Last edited by 785boats; 08-05-2010, 03:33 PM. Reason: replaced the link to O/S site
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      Cheers.
                      Paul.
                      i am going to try the leopard 2200kv in my new hotr cat on 4s,figure it should be goof for mid 50s
                      • forescott
                        • 3009
                        My castle 2200 in a 31 inch cat on 4s with an m545 runs in the mid-50's. I think you're speed estimate is right on!
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          alright
                          what hull,esc etc
                          • forescott
                            • 3009
                            Converted proboat thundercat with a turnigy 180. Its a heavy hull too!
                            • ozzie-crawl
                              • Sep 2008
                              • 2943
                              ah yes remember your build thread, hopefully the leopard performs as well as the castle (sure dam looks the similar)
