Bye-Bye DF 33 ; Hello Cyberstorm 32 !!
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    pictures
      • 9481
      Looks great Tony!
      • Brushless01
        • Apr 2010
        • 489
        Hi Tony what motor and esc did you use ?
        Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
        • properchopper
          • 7708
          Neu 1521 1.5D ; CC LV 240. Stay tuned - have some rudder mods coming
          • johnf
            • Dec 2009
            • 1086
            Tony, you have a vid of this thing running?
            Catching Air!
            • johnf
              • Dec 2009
              • 1086
              Never Mind! Saw the link. Runs good!
              Catching Air!
              • properchopper
                • 7708
                I have a bigger rudder blade setup coming in a day or so to keep it planted better in the turns. Really handles chop well with some hip-shake but doesn't get too upset. Will vid once dialed in a little better.
                • johnf
                  • Dec 2009
                  • 1086
                  Sweet! Can't wait to see it run with the updated setup buddy.
                  Catching Air!
                  • properchopper
                    • 7708
                    new rudder
                    Well it turned out that my home-made "no-bendum" rudder bracket was getting twisted from some full-throttle turns - One thing I insist on is good turning at speed; Sooo... Witness the "Super No-Bendum " Mark II Big Speedmaster rudder setup. Had to machine it some to get it to clear the trim tab. Inserted a 3/8" aluminum tube for the pushrod bellows. Shortened the rudder bottom some & installed the dual pickup plumbing. Added a 180 oz/in EXI servo [from Hobby Partz-$ 14.70 - all metal gear, centers perfectly, not bad for @ fifteen bucks]. Will report this weekend how it does.
                    • v-spec
                      • Jun 2009
                      • 1046
                      Hope this one don't bend! Isn't it supposed to have 3 holes drilled in it somewhere though??
                      • properchopper
                        • 7708
                        Nope, had enough reminders of my ex-wife.
                        • cybercrxt
                          • 2926
                          TONY! MY cyberstorm just arrived, and it is awesome! Can't wait to power it this evening. And you are right, it is more Orange than red! Mike
                          • properchopper
                            • 7708
                            Tony... I like your steering servo mounting!
                            Nice boat!
                            You MIGHT find out that it'll handle better if you get the prop closer to the transom. We shorten our Speedmaster struts up until the thinner portion is only about 1/2" or so beyond the step up.
                            Right you are !!! My DF33 didn't need the mod, but this boat's happier with the shortened stinger.
                            Tony
                            " If at first you don't succeed, skydiving's not for you"
                            • westbeach
                              OSE Rocks!
                              • 969
                              Tony, what is the length of your stinger from the transom to the end before the drive dog, after the mod? Thanks
                              Tony
                              HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
                              • properchopper
                                • 7708
                                I cut 18mm off the end. Just felt like the right length to chop off. Works good.
