XS Cat help
  • MattyTyler
    • 3
    XS Cat help
    hey guys,
    im currently building an modified XS cat. the plan is to use 2 12turn quad peak motors, with a gearbox, turning single prop with dual rudders, can someone please suggest a setup that i could use, for gearbox, and rudders.
    cheerz matty
  • Rex R
    • 1007
    Comment;
    dual motors isn't going to leave much room for batteries.
    • MattyTyler
      • 3
      thats why i wanted to use a gear box to get the motors close together, the main hull has also been widened to help allow for this.
      ill put some photos up tonight of a mockup if you want. please can someone reccomend where i can get a gear box and all the drive gear, as i havnt been able to find one.
      cheerz matty
        The Hughey gearbox is the best for your application. Try to find a used one on one of the boat forums, or call Ed at 317-566-9708.
        How do you intend to wire the motors, and how many cells do you intend to use? Dual 12-turns in parallel on 12 cells will pull serious amps and the motors will wear rapidly. Wired in series makes a more sense, power will be down a bit but with the correct gears you can be plenty fast.
        Why not forego the expensive, high-maintenance 05s on gears and run a single 700 motor direct? Performance will be plenty and it will be more fun and less work. That's what I'd do if I built it today.
        • MattyTyler
          • 3
          hey,
          i live in Australia so parts have to be orders over the web.
          i found this gear box http://www.drcwebservices.com/ffe/hardware.htm scroll down.
          i wanted to use the 12t motors as i already have them, and want to use them, was playing on using 12 3800mAh packs until 1 died so i am undecided on what batteries to use, i have a tekin gold fet 2 esc that can handle 24 cells, this was in my last mono that ran twin motors on twin props which was the plan for this cat, but space wont allow, i also found on the above link the single prop dual rudder setup,
          will this work?
          cheerz matty
