New outboard
  • F1 madness
    • Feb 2010
    • 788
    New outboard
    Well here you have it,been working on it for some time with a friend of mine who does C.A.D.
    Weve designed it to be able to run 540+ motors,with 12* angle adjustment,12mm height adjust,will be used with 3/16 flexi & stub shaft so a variety of props can be used,and be able to run upto 60mm props.
    As you will notice the motor mount is at an angle,this is to releive some of the friction on the flexi and the teflon liner.
    Im planning on having these done in cast alloy.we are just about to have the first 1 done in carbon poly plastic.theirs just 1 adjust to make before getting the 1st 1,and that to make the steering ears a little wider for more leverage and less stress on the servo.
    What you reckon
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
  • Rumdog
    • 6667
    Very nice!
    • bigpapa
      • Apr 2009
      • 2531
      sweet thats nice
      THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
      CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
      • F1 madness
        • Feb 2010
        • 788
        cheers guys,im planning on testing 2 of these on my twin outboard cat,with scorpion out runners,cant wait to get the 1st prototype back.
        • gerardobrandao
          • Mar 2008
          • 166
          F1 Outboard
          ..From the drawing smells me Autodesk Inventor or Solidworks ......
          Good to see the great work....i expect future releases......
          If you have access to rapid prototyping machinery yould make the mold in the blink of an eye......
          congratulaitons for the work..expect to see it ......real..
          • F1 madness
            • Feb 2010
            • 788
            Pass my mate does the cad,i can just about send messages and post pics LOL
            If i get enough interest then may decide to produce them forsale.
            Again my mate sorting out the the 1st model and moulds as hes in the know.
            I just designed on paper and gave him all the dimentions needed,i spent weeks reseaching and trying to design somthing to cope with bigger brushless & bigger props.
            Im testing the first 2 using HK40 series scorpion outrunners so should be interesting to see how they handle it
            • 6S HYDRO
              • 1325
              is it gonna be machined alum. or molded plastc- or cast alum?
              • F1 madness
                • Feb 2010
                • 788
                the first 1 is carbon poly,then will be molded for cast alloy
                • DPeterson
                  • 991
                  I like it. Very cool.
                  I am planning to do a 4S 34" tunnel in the near future with a true open power motor.
                  Was going to start to hunt down a 7.5 size Lawless. This looks like a better choice.
                  When you are ready to produce some please let me know.
                  Doug
                  Doug Peterson
                  IMPBA 19993
                  www.badgerboaters.com
                  • Doug Smock
                    • 5359
                    Very nice sir!!
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • Steven Vaccaro
                      Administrator
                      • 8934
                      Unless you are going to redesign the bushing and prop shaft for the better, I suggest using a current stubs and bushings availible. Like the HyperPerformace one. Its one less part to make.
                      By the way its quite nice looking.
                      Steven Vaccaro
                      • F1 madness
                        • Feb 2010
                        • 788
                        Cheers guys.
                        Alrite steve was going to pm later.
                        Also weve been looking at ceramic,sealed bearings and a longer stub shaft to mount the larger hubs on the bigger props.
                        Also there will be 2 water pick ups 1 for motor and 1 for ESC,but this will be an order choice depending on what your going to be running.
                        • bigpapa
                          • Apr 2009
                          • 2531
                          love the green fe-1 boat
                          • Gerwin Brommer
                            • Dec 2008
                            • 928
                            Sharpen the bottom of the vin to avoid lift ?
                            • sailr
                              • Nov 2007
                              • 7128
                              It would seem to me that with some of the thin elements of the unit that casting may produce some very weak points?
                              You may have a winner on your hands if it works out and you can sell it for a reasonable price! Regardless of its future, it sure is pretty!
                              QUOTE=F1 madness;210870]the first 1 is carbon poly,then will be molded for cast alloy[/QUOTE]
                              Mini Cat Racing USA
                              www.minicatracingusa.com
