Geico neon yellow - need paint
  • Jesse J
    scale FE enthusiast
    • 7818
    I don't plan on gettin her wet until the decals get here............... ya right! It can get wet! main thing I want the clear coat to cure before too much action. I go get some pics of her in the sun - ahhhhhh.
    Yes U spy, may be able to go out this afternoon, wanna see the Titan have a good long run. I fixed the rescue craft with a METAL pinion so back to reliable recovery. Need to test the Oberto too - since her latest surgery.
    "Look good doin' it"
    See the fleet
    • HYDROJERRY
      • Jan 2010
      • 2709
      Pics pics..
      • 6S HYDRO
        • 1325
        What happened with the piks
        • Jesse J
          scale FE enthusiast
          • 7818
          Pix? - ok here we are
          See the fleet
          • Jesse J
            scale FE enthusiast
            • 7818
            remember, I still have the graphics to add - Rod said they were being mailed today, so hopefully this weekend or shortly thereafter I will have finished product.
            See the fleet
            • Jesse J
              scale FE enthusiast
              • 7818
              Here is the glow paint. Over this I dusted lightly with the metal flake Duplicolor, then the clear. I will probably add another couple layers of clear once the graphics go on... too many blemishes!
              See the fleet
              • dana
                • Mar 2010
                • 3660
                looks awesome jesse! what kinda decals is he sending? vinyl or waterslide?
                • dana
                  • Mar 2010
                  • 3660
                  btw did you rebuild the rear end of this one? i seem to remember the transom looking different before no?
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    Dang, Dana, you got you some peepers!!! Thanks for the compliments! why yes, I filled in the deck at the transom, never liked that notch. AND I threw on some serious hardware - removed the inline and went offset monster rudder. Same bearingized strut, but big a$$ rudder -- just happened to have a chunk of aluminum sticking out where I had a rudder before that worked out ideal. Kinda wish the hardware were black like the inline, make it go away...." you didn't see annnnything"
                    Gonna slap some vinyl decals Rod the hydromaniac hooked me up with. Said they may go out in the post today with my freshly painted up mini xXx ----- ahhh can't wait.
                    btw your cooler just went out.... should be there by weekend
                    See the fleet
                    • dana
                      • Mar 2010
                      • 3660
                      thanks jesse, thats excellent! will be looking in my mailbox =). i must say i also like it better with the flush transom as well. that's how i built mine. im interested in hearing if it makes any difference in performance... yours and mine look so similar, of coarse i built mine off the same plans you did hehe. funny thing you got rid of the inline set-up because i just got the exact same in-line set-up you were using in natural aluminum finish. now i can finally test fit hardware then paint =) did you not like the inline hardware? should i know anything about this hardware?
                      • Jesse J
                        scale FE enthusiast
                        • 7818
                        No the hardware is great! and if anything gives way in flex shaft system, you have a retainer. I loved it, thing was that at speeds above 40-45 she got twitchy, what I am trying to smooth out. I wanna see if this thing will do 50
                        Under 45 it is superb, great turning both ways, great water flow, more than enough turn and not too much rudder.. no great set up, I just want to try the offset thing now.
                        See the fleet
                        • dana
                          • Mar 2010
                          • 3660
                          awesome! watching you vid's really inspired me to keep going on this project, even when i thot it was a lost cause... now thats its almost finished it really came out awesome. cant wait to get her wet!! one quick question about battery placement, where are your packs? ill attach some pics with my options. my guess would be the first pic for batteries, also is a pic of my hatch, you can see i added the turbine =)
                          • HYDROJERRY
                            • Jan 2010
                            • 2709
                            Sweet Jesse look real good, funny i used that same paint on some parts on one of my other boats,,,,
                            Dana i would think the first pic would be right but dont quote me on that,,, heres some pics of the one im doing...
                            • dana
                              • Mar 2010
                              • 3660
                              cool jerry. i just got the exact same inline hardware today =) my question is this.i am using .150 cable and i already installed 1/4 brass , because i want to use a teflon liner. problem is the strut is made for 7/32 tube, so the 1/4 brass does not slide into the strut, it just butts up to it. is this ok? or should i swap out for 7/32 brass without the liner? any thoughts? i figure i could just butt it up and put a piece of shrink tubing to hold the two together. this is my first ever build so im not to sure what to do at this point.
                              • HYDROJERRY
                                • Jan 2010
                                • 2709
                                Im not a big time builder but have done some hydros, this to will be my first cat,just got a Genesis in the mail last week and buildinga 18.5 mystic cat at the same time so yeah i just dove in i gess but i would think it would be better for the brass to slip in the strut just a hair to cut down on vibration but seems to me if it were mine i would do the heat shrink like you said but i would make sure you could slide the teflon up into the strut but again thats just me....
