BBY's HRP 06 build
  • RandyatBBY
    • 3943
    #31
    I got a little more done yesterday I mounted the motors. I will be settting up the stuffing tubes and mounts today. I decided to use CF plate for the housings.
    Uploaded with ImageShack.us
    Randy
    BBY Racing
    • johnnyhpr06
      • 16
      #32
      how about the water pickups any progress there, looks like were almost there.
      • RandyatBBY
        • 3943
        #33
        I finished the stuffing tubes yesterday and cut the holes for the water pick up. I will install the pickups today. I also ordered the tees and the outlets yesterday. I have taken some pictures but my back up computer does not have the ability to process the pictures. After I get my regular computer back I will post some pictures.
        Randy
        BBY Racing
        • johnnyhpr06
          • 16
          #34
          looks good ,i was real busy last time you called ,we didnt get a chance to talk about cowl locks
          • RandyatBBY
            • 3943
            #35
            No Problem I was wondering. But I have had a lot of other things to do. I just got the water pickups fitted, I have been at it a little today I also got the outlets in today thinking about ware to put them. I ned to glue the pickups in first.
            Randy
            BBY Racing
            • RandyatBBY
              • 3943
              #36
              Update on the pictures. I got a little behind loading pictures while my computer was in the shop getting the virus removed. But now it is fixed and I am back at it.
              I should have dusted/vacuumed it off before I took the picture
              Randy
              BBY Racing
              • RandyatBBY
                • 3943
                #37
                I got the water pickups installed and glued. I used Loctite 9462 Hysol adhesive on this build, good to know if you are installing threw hull application. It needs to sit for 24hr to cure.
                Randy
                BBY Racing
                • bonewar
                  • 587
                  #38
                  Randy,
                  Can you please explain what the extra brass tubing is for on the stuffing tube.
                  I really need a good oiling idea for my M12 project.
                  Would love to no how you go about making yours.
                  Thanks mate.
                  Bye the way very nice build .
                  Bonewar
                  SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                  • JohnZ
                    • 267
                    #39
                    Absolutely fabulous, Randy! Is this a glass or ABS hull?
                    What hardware are you using? I've never seen these before.
                    BTW I polished the ride stabilisers and turn fins on my O.M. 26, they look pretty good. I used my Dremel and a number of polishing pads. The polishing compound was Mothers Aluminum Polish.
                    • RandyatBBY
                      • 3943
                      #40
                      Originally posted by bonewar View Post
                      Randy,
                      Thanks mate.
                      Bonewar
                      There is no Teflon tubing in this stuffing tube. It is double layer brass tubing then it is Hard soldered on both ends. then the extra tube is soldered and drilled. I use a mix Slick 50 and STP pumped in to the reservoir.
                      Randy
                      BBY Racing
                      • RandyatBBY
                        • 3943
                        #41
                        It is a swiss made boat CF/Kev hull, Link below
                        http://www.swissmodelpowerboatteam.ch/index_en.htm
                        Randy
                        BBY Racing
                        • RandyatBBY
                          • 3943
                          #42
                          I came in to the shop today to get a little done on my Oiler built the basic holder for the distribution center. Hear is what I got done today The sink is plug ed up and I need to fix it so no more today on this project.
                          Randy
                          BBY Racing
                          • johnnyhpr06
                            • 16
                            #43
                            never seen this type of oiler system ,i'm likeing the way it looks though ,is it gravity fed or pumped in ?
                            • RandyatBBY
                              • 3943
                              #44
                              It will be a leach system, There will be a pump to fill the tank and prime. I have been testing with several designs over the last couple of years.
                              Randy
                              BBY Racing
                              • RandyatBBY
                                • 3943
                                #45
                                Getting ready to mount the oiler.
                                Randy
                                BBY Racing
