Spots Rico 20 Mono build.
  • Spot Me 2
    • 770
    I picked up a Rico 20 Mono hull from a member here. The hull was original build by Mad Mike with a wet well design. (kinda different/cool). I am going to put a Neu/castle 1515 1y on 4s-5s with a skywing 200amp esc.
    What prop would be a good starting point for this combo on 4s?
    MMGMMarine
    RobertsonRacing
  • Rumdog
    • 6667
    Sweet! I bought his other Rico mono! It was the green one with Monster graphics. I ran a Neu/castle 1518 1800kv on 5s2p. With a x447, or x548, it FLEW. Gps'd at 58mph! I also ran the Neu/castle 1515 1y. The best prop for that setup is a m445. Is it for sport running? If so, go with the 1518 if you don't already have the 1515. The extra oomph is well worth it!
    • Rumdog
      • 6667
      oops, sorry. It wasn't Mad Mike's. It was Mike Martins.
      • Spot Me 2
        • 770
        Yeah, its for sport running. I already have the 1515. What kind of temps where you getting with the m445 and how many amps were you pulling?
        MMGMMarine
        RobertsonRacing
        • Rumdog
          • 6667
          Motor temps were right around 120 degrees. Seaking 180 was about the same and 4s2p 10,000mah total at 30c were just ambient temps. I never actually ran a logger on it, but amps were prob averaging around 120. I wouldn't run 5s on that setup though. It's pretty hot to start. Prop up just a little and amps spike!! I smoked a 180 seaking with that setup and a x645. It is an AWESOME running hull! My favorite mono by far!
          • Spot Me 2
            • 770
            What speeds were you seeing with the M445?
            MMGMMarine
            RobertsonRacing
            • Rumdog
              • 6667
              Right around 50mph on gps
              • Spot Me 2
                • 770
                What about a Y537/3? It should be ok on 4s and move out on 5s and be easy on the amps......or is it too small to move a hull of this size?
                MMGMMarine
                RobertsonRacing
                • Spot Me 2
                  • 770
                  No thoughts on this prop anyone??
                  MMGMMarine
                  RobertsonRacing
                    Probably not enough pitch for much over 40 mph. That motor would be a bit weak on 4S (low rpm) but on 5S I'd go with an m545 or m645. Just watch the heat and try to keep the boat on step.
                    • Rumdog
                      • 6667
                      yeah, i didn't catch that. I thought it was a 1y. I'd run hs and a x645 or m645 like Fluid stated.
                      • Spot Me 2
                        • 770
                        My bad it is a 1Y. I changed the first post. Does the Y537/3 make more sense now?
                        MMGMMarine
                        RobertsonRacing
                        • BakedMopar
                          No Mo Slipah
                          • Sep 2009
                          • 1743
                          These hulls are awesome!! With a 1y I would start with a 442 and work your way up. Depending on how high your struts located a 37mm might not be enough diameter.
                          • Spot Me 2
                            • 770
                            What about this motor on 10s instead of the neu????
                            MMGMMarine
                            RobertsonRacing
                            • Spot Me 2
                              • 770
                              The little screamers motor above with this VooDoo prop. What do you think?????
                              MMGMMarine
                              RobertsonRacing
