H&M intruder s rebuild
  • DINO7
    • Jan 2009
    • 165
    i fried my tenshock,so i decided to rebuild my intruder..
    carbon-aramid , mooving cog litlle forward and new motor 36/80/2000kv..
    H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
    MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
    BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
  • tth
    • Apr 2008
    • 1600
    I do like the "splatter guard" !!! I think Doug Smock was the first one that I can remember of doing that. Great design tho.
    • bea5017
      • Aug 2009
      • 173
      like them water tube holders..
      • Jesse J
        scale FE enthusiast
        • 7818
        like the plaid, I used to have a pair of shorts with that pattern. Very stylish and clean set up! what is the material of the rails? Sweet work, what hardware?
        "Look good doin' it"
        See the fleet
        • DINO7
          • Jan 2009
          • 165
          plate is H&M fiberglass painted black...hardware from H&M...
          • CornelP
            • 793
            Nice work there... I started work on a similar hull and already lined with carbon/kevlar (same as yours, I suppose it's hobby king). The motor/servo support will probably be aluminum or carbon, cut on a router.
            What motor angle are you using? Could you estimate it? Thank you in advance.
            Cornel
            • DINO7
              • Jan 2009
              • 165
              lehner 1950
              x440/3 by egneg..!!!!!
              turnigy 5000 40c 4s
              etti 150 opto
              92km...
              salt water video
              • CornelP
                • 793
                Very very nice!! On my setup I got up to 82.8kph with a very bad CG setting. I later moved it forward but did not take any gps reading...
                • Heath M
                  • Mar 2008
                  • 865
                  Hi Guys,
                  What COG are you running on this boat? I struggle to keep mine on the water.
                  Setup is TP 40/70 2350KV 4s1p M445 91Kph
                  Brisbane,QLD, Aussie
