This is going to be cool. I will be fitting the UL-1 hatch and canopy to my new whiplash build. I will cut off the original nose piece on Whiplash then run a solid piece of shaped pine across front (sponson to sponson).
Whiplash / UL-1 Hatch and Canopy
No turning back now. I cut original nose piece off using scroll saw. UL-1 hatch follows Whipash's contour perfectly.Last edited by detox; 07-05-2010, 12:00 PM.
Coming at ya! My wife shot this Dragonfly today.Last edited by detox; 07-29-2010, 04:02 PM.
Just like in diagram below. I will remove the cross piece before I add fiberglass and epoxy to the floor.Originally posted by T.C. View PostLooks good, where are ya gonna put the batt. packs?
T.C.Attached Files
Making progress. This 9 5/16" long piece of bass wood was cut on a table saw then front edge was sanded round (more shaping is needed). I will then blend in the bottom edge to battery tray using balsa or bass wood.Last edited by detox; 07-13-2010, 09:45 AM.
Thanks Jeepers. It will be easier to tape and use less tape . Plus the UL-1 cowl/hatch looks cool.
Here's picture with measurments of cross piece. This will save you lots of time if you ever decide to do this mod. I cut this from block of bass wood using table saw.
Midwest #4421 http://www3.towerhobbies.com/cgi-bin...?&I=LXAT45&P=7Attached FilesLast edited by detox; 12-03-2011, 07:30 PM.
Waiting for epoxy to cure on maple motor mount blocks. Blank 3/16" Pop rivets were glued in then threaded using 6/32 tap. I mounted motor plate same distance from transon as my Raptor rigger so that same length drive cable or wire can be used. COG will be OK......I HOPE.Last edited by detox; 07-14-2010, 04:10 PM.
