F1 24" Finally finished.
  • F1 madness
    • Feb 2010
    • 788
    Well iv finally got the rest of my bits together,and now my F1 24" is finally ready to get wet.
    Its running a hobbywing 3600 kv water cooled motor that iv mounted on a modified original dolphin outboard,up graded flexi and ballrace sealed bearings on stub shaft and twin cooling pick ups,hobbywing 60amp esc,futaba 3004 servo for steering with twin cable (push-pull system).Lipos are overlanders 3200 mah,20C 3s 1p,11.1 volt.Iv got 3 props to try 31mm,34mm,38mm.
    But will probably just stick to the 31mm.Weather depending will try tomorrow and hopefully get a vid or 2.
    http://s577.photobucket.com/albums/s...79/F1%20boats/
    Daz from sunny England
  • Jedi Master
    • 242
    Very tidy....good job!!!
    Do or do not, there is no try!!!!!
    Aeromarine Titan 29 H&M Hawaii Kai III Proboat Stiletto ML Boatworks PS295 (No.8)
    • bigpapa
      • Apr 2009
      • 2330
      looks awsome great job, cannot wait to see video of the test run
      THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
      CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
      • F1 madness
        • Feb 2010
        • 788
        Cheers guys.
        the weather looks abit better today,but surposed to be even nicer tomorrow,so should get the chance to give it a run and hopefully do a bit of setting up,as soon as iv got a vid ill post it
        • F1 madness
          • Feb 2010
          • 788
          Well heres somthing interesting just weighed the boat out of interest with everything in inc batt,1.2kg cant beleive how light this is.
          So will definatly be interesting to see how it goes.
          • Xfactor
            • 861
            Boy thats nice.
            • F1 madness
              • Feb 2010
              • 788
              Well took it out and this was the result,heres a link to some vids:
              the the 1st 2 are last runs with the 34mm prop and abit of an angle adjustment on the outboard.
              A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
              Boy was i surprised and hope you are to.
              will try and get some better vids tomorrow hopefully.
              • F1 madness
                • Feb 2010
                • 788
                Originally posted by Xfactor View Post
                Boy thats nice.
                Cheers bud,took alot of working building this from scratch and was worth it,after watching how it goes.
                • F1 madness
                  • Feb 2010
                  • 788
                  well heres a run from today,bit dissapointed i could do 1 pass ripping up the canal,then the esc is shutting off and only giving me half the power,think i need a bigger esc.click on pic to view the vid
                  thought id try and lower the out-board a little heres the result lol
                  • sailr
                    • Nov 2007
                    • 6924
                    With a 3600KV motor on 3S I would suggest a 432 prop. Here are some possibilities.
                    1. Weak battery (even though brand new, it may not be able to sustain high discharge) and is approaching LVC. I have had this happen and puzzled and puzzled only to be solved by a different battery.
                    2. ESC approaching temp cutoff because of too much prop.
                    3. Prop too deep in the water, drawing too many amps. Where is your prop shaft located in relation to the bottom of the sponsons?
                    Other than that, I'm as mystified as you! Hopefully somebody else here can be more helpful. The ride attitude of the boat looks good so I think you have the angle of the motor correct.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • F1 madness
                      • Feb 2010
                      • 788
                      Cheers bud iv tried 3 batterys still the same and only running a 31mmd,1.4p prop iv tried raiseing the prop,and is centre line of the prop is just above the bottom of the sponsons and still the same,looks like i need a bigger esc
                      • sailr
                        • Nov 2007
                        • 6924
                        You could be right about the bigger esc. I'm surprised it doesn't get really hot though if that is the problem. I would be surprised if that motor/prop is pulling that many amps but it is difficult to know for sure. Maybe it is a faulty ESC as well.
                        Where do you have the timing set for that motor? I imagine it's just a 2 pole. I wouldn't run it any higher than about 5 degrees advance. You might try that. Might have some bearing on the issue but not sure.
                        Mini Cat Racing USA
                        • F1 madness
                          • Feb 2010
                          • 788
                          iv not set the timing,iv just plugged it in and set the throttle range,ill find the instructions and have a look to see how i adjust it.
                          • Xfactor
                            • 861
                            Id step down on the prop 3s on a 3600 kv motor might be getting on the hot side of things . Try a 430 or a 427.
                            • Xfactor
                              • 861
                              Youd be surprized at the difference a few mm on prop size makes.Try a smaller prop.
