Phil Thomas U-10 8700 FE Smokin Joes 1/8th scale Hydro Build
  • cybercrxt
    • 2926
    Well, I started my U-10 Smokin Joes build over the last week. This will be an electric setup. I got Speedmaster hardware, Virgina Craftsman turn fin, Neu 1527 1.5Y motor, OSE water cooler, a really really nice motor mount made by Williams racing. Best motor mount I have ever owned honestly. This boat will be run as 10s1p, and the ESC I have yet to decide on. I also have the PGI decal set, and Dupont Specktramaster yellow, an HOK Purple.
    So far, I have mounted the rudder, turn fin, spot glued the motor mount, and I took the 3 piece cowling set that Phil sells with it and bonded the front two pieces together, cut the rear turbine cover off the rear hatch and bonded it to the front two pieces. Since the underside will have its own hatches, I needed the cowling to come off in one piece to access the battery hatch cover. I will start on the bonding in the fin attachment points at the rear, make the hatch covers and install the strut next. Enjoy for now. Mike
  • cybercrxt
    • 2926
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      What ? No WOF ? - Looking good
      • cybercrxt
        • 2926
        Lol, Well, I needed the weight savings this hull can offer. It should come in around 10lbs with motor/ hardware, minus batteries. I want it to be 10s1p, so its imperative!
        • m4a1usr
          Fast Electric Addict
          • 2036
          How's the build progressing Mike?
          John
          Change is the one Constant
          • cybercrxt
            • 2926
            Hey I did make some progress, but had to get started on some other 1/8th scale projects, so this one is being put aside for a short time. I am working on that '82 Executone right now. I have the other thread going, and it will be updated greatly today with new pics! Mike
            • cybercrxt
              • 2926
              Ok, here are some updates on the build. I spent the last few days working on it, and here we are. Its actually closer to priming then I would have ever expected after 2 days work! Mike
              • cybercrxt
                • 2926
                • cybercrxt
                  • 2926
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2751
                    Nice work on the hatch!
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1743
                      You do some outragoues work. Good Job!!
                      • old guy
                        • 710
                        Nice let me know if you put it up for sale
                        • cybercrxt
                          • 2926
                          If I did, it would be listed for no less than $2000 rtr. If you have that to spend on one just let me know, Mike
                          • dreamland s4
                            • Dec 2010
                            • 347
                            did this build ever finish?
                            If the #2 pencil is the most popular, why is it still #2?
                            • photohoward1
                              • 1781
                              Not yet! He sold it to me last fall and I started working on it. Not really any farther than before. I had to redesign some things to fit the 6500 bats. Enlarged the battery area a bit and changed the motor mount. I need to get going again on it.
                              Howard
