jae 12 fe video
  • Chuck E Cheese
    • 2136
    jae 12 fe video
    here is a video of my jae 12 fe. still needs a little prop work and this is on a turnigy 3600mah 30c battery marked august 2009 (almost 1 year old and puffy)
    see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
  • jcald2000
    • 786
    No wonder that battery is puffy, they are all going to puff if you run them down that far!
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      What's the setup Chuck? We are going to come up in the first week of August.
      • Chuck E Cheese
        • 2136
        nice....... it is ul-1 spec stuff.. you have to let me know when you are coming and where you are staying. we usually get together on saturdays at ala moana beach park. let me know and i can bring some extra stuff for you to run.... hows that skunkworks cat? i saw the build and vedio but i am wondering if it turns???? i have a small pond and have been thinking of building a twin so i need one that can turn wide open..
        as for running them "down that far" that is not what puffed them, i did it with a 1515 in another boat so they were puffy before i started. those batteries are almost a year old and have about 75 cycles on them. even though they are puffy i have a hard time getting rid of them because they still put out. i have 4 more 4000's coming so that was probablly their last run. i can do a 3 minute run and use 2800 mah. there is nothing wrong with using 2800 off of a 3600 mah pack. i usually run 1 4000mah 40c for 3 minutes. that was just the only batteries i had left because i was testing props all day....
        • BakedMopar
          No Mo Slipah
          • Sep 2009
          • 1743
          We will be comming up on August 4-9. We will be staying with a friend. Not too sure on what our intinuary will be but I will let you know. The Skunworks cat doesn't like tight corners. I'll keep in touch.
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1743
            Chuck did you just use the gas version or did you use plans and made changes?
            • old guy
              • 710
              Nice Chuck. so what set up am I'm going to have to use to get mine to go 70mph to keep up with my nitro one ???
              Old guy
              • Chuck E Cheese
                • 2136
                it is the nitro kit. i used the sponsons and just traced the bottom and boom tube mounting locations then made the tub from scratch... i run the ul-1 motor/esc. i am in the process of building a 21 size fe now that is going to use a neu 1515 1y and i am going to play with the castle/neu 2650kv 1515. hoping to get some real speed out of that one. i am kinda bored with teh standard 21fe with the ul-1 motor. it handles so good it almost feels slow.
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Wow, fast little bugger! Looks set up very well the way she runs.
